Author Topic: under boost issues...here we go again!  (Read 28926 times)
Offline Chris.
Re: under boost issues
« Reply #40 on: 27 October 2011, 21:50 »
Set it up closed then wind the nut on 3 turns.  Usually puts you at a good preload!
Click For Build Thread
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #41 on: 28 October 2011, 09:43 »
Set it up closed by that you mean hold the penny valve closed wind the nut up to it then add three turns of preload?
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline Chris.
« Reply #42 on: 28 October 2011, 22:59 »
Thats the way!
« Reply #43 on: 29 October 2011, 00:54 »
nice one chris.
« Reply #44 on: 29 October 2011, 02:33 »
nick are these are good? cant find yellow tops for the love of money these flow 315cc same as the yellow tops just not sure if the ohms are the same as the yellow tops
http://www.ebay.co.uk/itm/VW-G60-VR6-C20XE-C20LET-UPGRADE-RECON-INJECTORS-RALLY-/170716597030?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bf808b26
« Last Edit: 29 October 2011, 02:35 by blade4real2004 »
Offline tshirt2k
  • Been there...Done that...
« Reply #45 on: 29 October 2011, 08:27 »
They are high impedance so should be ok.
Mk3 ABF 16VT Megasquirt V3
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #46 on: 29 October 2011, 11:59 »
They're not as high impedance as the C20LET yellows and the info I've found suggests they are from a Volvo turbo of some description. I'll check the info I've got on my other PC once I get on there so don't rush into anything  :wink:
« Reply #47 on: 29 October 2011, 13:53 »
alright cheers wazzzer
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #48 on: 29 October 2011, 19:01 »
http://www.injectorcleaning.co.uk/flow.htm
They are rated the same on paper.
 01455 617233
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #49 on: 29 October 2011, 19:14 »
exactly the same then :afro:
