Author Topic: under boost issues...here we go again!  (Read 29362 times)
Offline blade4real2004
  • golf gti with a touch of .:R
Re: under boost issues...here we go again!
« Reply #60 on: 02 December 2011, 18:02 »
they look like they are linked to you replacing the lambda? You tried clearing them and seeing if they come back?
yer i cleared them when i changed the turbo over but it come back again i think it went into limp mode  earlier to as it wouldnt boost past 10psi but now i cleared it its boosting to 20psi again
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
« Reply #61 on: 02 December 2011, 18:03 »
Has it been mapped to suit? If not do that first.
i was thinking that earlier on but so i tried getting hold of nick but no luck yet  :cry:
Offline Chris.
« Reply #62 on: 03 December 2011, 12:22 »
What turbo did you have on before?
Click For Build Thread
« Reply #63 on: 04 December 2011, 18:17 »
k03-052 (k03s) stage 2 rtech but it not custom nick come down and loaded it on which he dont do no more..
i boost leak tested it to had a slight leak on the one pipe on the n75 and on the tip on the turbo so sorted them will see if that has sorted it
i also cleaned off a load of sensors lambda sensor intake sensor throttle body
im wondering if with the k04 now on there and the injectors on there limit on a stage 2 k03s setup now with the k04 it cant cope
i would guess nick would know if that could be my problem
« Reply #64 on: 11 December 2011, 15:04 »
lambda changed again cleared code just need to run it again now see it it comes back fingers crossed it was just a dodgey lambda
Offline coolio
« Reply #65 on: 11 December 2011, 17:14 »
my car have developed an under boost issue and when i plant my foot down it goes into limp mode , just wondering what equipment did u use to do the leak test ??
« Reply #66 on: 11 December 2011, 18:05 »
i bought a boost leak tester from the US mate is a good bit of kit awesome way to find leaks never would of found the two i had without it
Offline coolio
« Reply #67 on: 11 December 2011, 18:28 »
u got  link for it mate ?
Offline tshirt2k
  • Been there...Done that...
« Reply #68 on: 11 December 2011, 19:11 »
You dont need to buy a kit. a few plumbing bits and a shrader valve does the trick (And a compressor with tyre inflater). You just need a end cap that fits in where your maf connects to the TIP.
Mk3 ABF 16VT Megasquirt V3
« Reply #69 on: 11 December 2011, 19:47 »
i thought of doing that but i just thought for the price of the kit it saved me the hassle
