Author Topic: under boost issues...here we go again!  (Read 29094 times)
Offline blade4real2004
  • golf gti with a touch of .:R
« on: 23 October 2011, 11:27 »
since fitting THS front mount cooler my boost spike had gone from 20-22 psi to 15-16 psi been over the car for boost leaks with a boost leak tester was one on the vac line right on the fpr and one on the breather pipe under inlet (was a pin hole) i fixed these but car still not hitting near 20psi also the car feel flat its lost that punchy torque it had before fitting the front mount
anyone got any ideas what i can look at to try to get it back to how it was?
my mapping i got on there is stage 2 rtech (generic) the car feels like as if someone has taken the mapping off it is best way to discribe how it feels to drive
« Last Edit: 02 December 2011, 13:10 by blade4real2004 »
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: under boost issues
« Reply #1 on: 23 October 2011, 11:54 »
It could be a number of things, mapping as the drawing of more air to fill the FMIC can make up the load so the ecu thinks its filling the cylinders with enough air, could also be a leak, a valve, faulty maf, vac lines ect..  What you need to do is log the requested load vs actual load against the n75% reading to see whats going on.
 01455 617233
« Reply #2 on: 23 October 2011, 12:15 »
cheers how you do that? i got vagcom so can do loging but not done anything like that yet. i also checked it with vagcom and no fault codes on there. do you think with your generic stage2 software (was put on in aug '99) would cause the issue as the generic is set for standard intercooler etc, the issue started instantly after fitting the new cooler if that any help
im thinking of changing the injectors etc like chris has and having the mapping tweaked but i need to find out what is going on first as its like a 3hr trip from barry (wales) to get up to you.
how much is the fuel pump you supplied to chris and the throttle body mod and what will the cost be to tweak the mapping?
forgot to saying engine is an AGU
« Last Edit: 23 October 2011, 12:25 by blade4real2004 »
Offline RTechUK
« Reply #3 on: 23 October 2011, 13:02 »
Its all down to your car actual setup and how the map responds.
You need to log blocks 25 to see whats going on.#
 01455 617233
« Reply #4 on: 23 October 2011, 13:27 »
ok ill log 25 is there a way to make it i.e a way the car needs to be driven?
Offline Chris.
« Reply #5 on: 23 October 2011, 13:40 »
full throttle run in 3rd gear is usually best. low RPM - redline!
Click For Build Thread
« Reply #6 on: 23 October 2011, 13:44 »
ok cheers chris i got to go up my mums today so ill try and log it on my way up there
« Reply #7 on: 23 October 2011, 16:33 »
Going to be going out now in a bit shall I log measuring block 002 as well or just 25
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #8 on: 23 October 2011, 17:21 »
Might be worth logging the MAF too
I had a similar problem and it turned out to be a combination of the MAF and actuator
« Reply #9 on: 23 October 2011, 18:51 »
Couldn't do a log on the way out as was a bit to much traffic so will do it on my way home now just to double check I'm going into measuring blocks not single block then change one group to 025 and the other to 002 then click the log tab at bottom right then start when I'm read to start the logging?
