The garage
under boost issues...here we go again!
5
6
7
8
Topic: under boost issues...here we go again! (Read 28894 times)
blade4real2004
GTI forum regular
golf gti with a touch of .:R
Re: under boost issues
Reply #50 on:
29 October 2011, 21:29 »
awesome cheers nick and waz ill sort out getting a set of them then
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread -
http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
blade4real2004
GTI forum regular
Reply #51 on:
30 October 2011, 19:07 »
sorted injectors today so now i got the pump and actuator left to sort out should recieve the injectors mid week ill sort out the actuator end of the week once i got that ill fit that on straight away,
my build thread -
blade4real2004
GTI forum regular
Reply #52 on:
02 November 2011, 09:16 »
Actuator ordered looks like I got a job for the weekend
my build thread -
blade4real2004
GTI forum regular
Reply #53 on:
05 November 2011, 11:21 »
Looks like my plan might be changing my mates thinking about getting a camper now if he does I'm going to be having his k04 setup off of him
Nick I have i have bought a forge actuator now so is it worth putting it on that? Got a yellow spring in it? I should be having his turbo and the green injectors from him so if I use my vr maf and a 255l pump am I ready to rock?
my build thread -
blade4real2004
GTI forum regular
Reply #54 on:
09 November 2011, 15:48 »
its deffo on now for me having my mates k04 so will be pulling it off soon as we got a touch of dry weather and get it fitted onto mine
so my k03s will be up for sale and so will the 315cc injectors and there not going to be needed now
nick if you can give me any info on my last post that be awesome mate
my build thread -
blade4real2004
GTI forum regular
Reply #55 on:
27 November 2011, 17:36 »
Boost issue resolved turned out to be a faulty lambda which wasn't showing a fault code till I went through a deep flood puddle and coursed the lambda to flag a code when it coughed and cut out twice took out the lambda to find it been wearing on the heat shield and worn through the outta casing of the wire
Replaced the lambda and now fault free 22psi of boost and now with the the k04 fitted its even more torquey can't wait for the remap now
my build thread -
Wazzzer
10k hero
Golf GTI 1.8T AGU
Re: under boost issues...issue resolved!
Reply #56 on:
01 December 2011, 21:08 »
excellent stuff mate
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
blade4real2004
GTI forum regular
Reply #57 on:
02 December 2011, 13:09 »
k here we go again
fitted the k04 now got these fault codes anyone got any ideas?
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
00561 - Mixture Adaptation
14-00 - Adaptation Limit (Add) Exceeded
12-00 - Adaptation Limit (Mul) Exceeded
have looked on there web sites on the means of the codes but does not give much help with these codes
my build thread -
Wazzzer
10k hero
Golf GTI 1.8T AGU
Re: under boost issues...here we go again!
Reply #58 on:
02 December 2011, 13:53 »
they look like they are linked to you replacing the lambda? You tried clearing them and seeing if they come back?
tshirt2k
Been there...Done that...
Reply #59 on:
02 December 2011, 14:00 »
Has it been mapped to suit? If not do that first.
Mk3 ABF 16V
T
Megasquirt V3
5
6
7
8
The garage
