Author Topic: under boost issues...here we go again!  (Read 28896 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: under boost issues
« Reply #30 on: 26 October 2011, 22:23 »
wicked ill add one to the recipe for POWER! i managed to pick up a 3" maf for £16 delivered just injectors pump and actuator.
nick with the injectors is it posible to use 350cc or will they be to big and i should stick with the 315cc ones?
The need to be the same ratio as your maf size, around 310cc for the VR6 maf.
 I have managed to get the 310cc Calibra yellows to fuel 100% with the stock maf, but running the stock maf limits the peak air flow reading,  it could be fudged to read higher than 187gs but would screw all the load axis up in the mapping.  So IMO the best was is 310cc with 2.75" ID maf (VR6)
 01455 617233
Offline Chris.
« Reply #31 on: 26 October 2011, 22:25 »
I had to remove the banjo.  No way was the nut coming out even with the turbo out the car.  Dont think downpipe needs to come off though, you can just get into the lower nuts with it on.  Well ive done it a few times.  Leave the 3rd one behind the banjo out.....far easier IMHO and no future messing on.
Click For Build Thread
Offline RTechUK
« Reply #32 on: 26 October 2011, 22:31 »
Trust me it can be done.. :wink: Jim has to take the banjo off aswell, he aint got the skill like me.. :grin:
 01455 617233
Offline Chris.
« Reply #33 on: 26 October 2011, 22:35 »
By any chance do you cut it off? lol
Would like to see how you do it ;)
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #34 on: 26 October 2011, 22:39 »
Alright I'll get some yellow bad boys. Can't wait to get it remapped again now missing that pull it had before. Hehe how do you get the 3" maf in the tip? Loads of k y jelly and plenty off pushing and swearing lmao
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline Chris.
« Reply #35 on: 26 October 2011, 22:40 »
Attacked it with a grinder LOL
Grind edge down to reduce thickness.  Then swear lots as you try to stretch the TIP over it.  Just about possible!
« Reply #36 on: 26 October 2011, 22:45 »
Looks like this weeks job when the maf comes . I got dremel here so with give it the slim fast diet and " slip it in"
Offline Chris.
« Reply #37 on: 26 October 2011, 22:46 »
Nice tight fit mind :P
« Reply #38 on: 26 October 2011, 23:57 »
it be snug when im finished it with it lol or bust hahahhaha actuator going to be funy   :huh: great fun playing with the turbo and manifold number of times i had that manifold off lol
« Reply #39 on: 27 October 2011, 12:28 »
Once the actuator is fitted how do u setup the ajustments?
