Author Topic: Dan's mk2 8v to ABF project **Build For Le Mans??**  (Read 165773 times)
Offline tech1889
  • Mk2 GTI FTW !!
Can you get a pic of the front of the power steering pump and bracket please ? I'm going to move the bracket for better access..
The m/c is off a SEAT cupra might be the turbo one not sure.. £30 on eBay with adaptor as you need adaptor to fit mk2/3 servo
Offline tech1889
  • Mk2 GTI FTW !!
SEAT ibiza cupra that m/c just checked  :wink:
Just got in from a late shift to a little goodie.. Brand new genuine HELLA rad for the pricely sum of £29 cant beat that !
Offline earlymk2
Nice one thanks very much.
Offline jmsheahan
Sorry bud I completely forgot to do this, will try grab a pic up the garage tomorrow.
Offline tech1889
  • Mk2 GTI FTW !!
Offline tech1889
  • Mk2 GTI FTW !!
256mm front brake setup fitted ready to go 280 when im ready.. got two new flexi lines delivered but think they the wrong ones  :sad: time to order up soon
Offline tshirt2k
  • Been there...Done that...
Pics?
Did they go on ok?
Mk3 ABF 16VT Megasquirt V3
Offline tech1889
  • Mk2 GTI FTW !!
Yer went on a treat mate.. i soaked the mk2 track rods with plusgas and used stilsens and they came off a treat.. only problem is on the track roads my track rod ends are about 20mm further out each side and not held on with a lot.. does this mean i need a mk3 rack ?? also i need tdi shafts :(
Offline tshirt2k
Did you use the mk3 track rod ends ? As long as there's a good few threads going into them they should be ok.
Yea I think you'll need shafts. Mine went with the engine and box.
Offline tech1889
  • Mk2 GTI FTW !!
yer they are on about 4 full turns it just worries me as the mk2 items went on another 20mm i dont want these coming loose.. im sure tdi shafts will be cheap as chips down a scrappy or ebay.. will get pics soon of the brakes.. still waiting on my friend to run my lines..
Corrado pedal box and master cylinder on route all i need is line from master to slave and master to reserviour..
