Author Topic: Dan's mk2 8v to ABF project **Build For Le Mans??**  (Read 165975 times)
Offline tshirt2k
  • Been there...Done that...
You got a pic from underneath? was refering to the gap as mk1's are worse.
Mk3 ABF 16VT Megasquirt V3
Offline tech1889
  • Mk2 GTI FTW !!
Can get one tomorrow mate but not got one to hand..
Just cant seem to remember how to fit the steering pump lol might be missing a bracket  :undecided:
Offline tshirt2k
Could be your problem. Does look a bit out of line.
Offline tech1889
  • Mk2 GTI FTW !!
Everythings aligned might be photo making it look out of align mate..
Offline jmsheahan
I'll snap a couple of pics of the P/S setup on mine tomorrow if it helps.
Offline tech1889
  • Mk2 GTI FTW !!
please mate :) what setup you using ?
Offline jmsheahan
Standard ABF setup mate, using Mk2 lines and P/S unions though. Here's a few snaps from the garage earlier, hope it helps. If you need anymore snaps give us a shout.
Top view of alternator setup - there's probably at least a fingers worth of gap between the engine and the chassis leg but the pic makes it look a bit closer. Looks about the same as yours:
Underside of P/S assembly
« Last Edit: 04 June 2012, 18:07 by jmsheahan »
Offline tech1889
  • Mk2 GTI FTW !!
Cheers mate any chance you could post a pic of the front p/s assembly ? Thankyou
Offline jmsheahan
Which bit do you mean specifically chap? The other side (reservoir etc)? Read about the issues with the bracket you were having - might not be able to help there as I'm using an 020 box rather than the 02a box. Think the G60 and corrado res is up by the washer bottle - might be worth trying to source that setup if you can't get it work.
Offline earlymk2
Hello mate nice project. What is the brake master cylinder from? Could do with one of those for my 20v T conversion.
