Author Topic: Dan's mk2 8v to ABF project **Build For Le Mans??**  (Read 165256 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Dan's mk2 8v to ABF project **Build For Le Mans??**
« Reply #371 on: 24 March 2013, 01:36 »
Yer i looked at them above exhaust gaskets before but ive fitted ones like that to friends cars and they like cardboard i prefer layered metal ones if i can find some.. im not fussed at the moment as its not even running..
Offline tshirt2k
  • Been there...Done that...
« Reply #372 on: 24 March 2013, 16:50 »
Those are the standard exhaust gaskets. Run the same on mine.
An ABF downpipe to cat gasket is a large bore 3 bolt MLS gasket.
Mk3 ABF 16VT Megasquirt V3
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #373 on: 24 March 2013, 21:07 »
Cheers.. Not needed at the moment need somewhere to delete the immobiliser for me..
Offline Len
« Reply #374 on: 25 March 2013, 11:50 »
Good to see you making progress Dan! :wink:
www.sas.org.uk
www.the-ace.org.uk
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #375 on: 25 March 2013, 12:18 »
Cheers Len will have to pop and see you when it's done  :smiley: hope your well
Offline Metallix
« Reply #376 on: 26 March 2013, 09:53 »
The gaskets for the manifold are fine and very similar to the ones you get from VW.  Can be used again and again.
IMO the layered ones come apart if you have to uncouple the downpipe for any reason.
Immob?  You have immob ECU but no box/transponder/key/chip?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #377 on: 26 March 2013, 12:34 »
Yes I broke the mk3 and forgot to get them bits before scrapping it two years ago
Offline Len
« Reply #378 on: 27 March 2013, 12:52 »
Yep very well thanks!
Next time you come down my way give me a bell.  :laugh:
www.sas.org.uk
www.the-ace.org.uk
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #379 on: 02 April 2013, 23:04 »
Will do then..
Spent a few hours on the beat today after i got home from Marrakech last night.. The parts i ordered from VWS arrive but the alternator belt and PAS belt were wrong sizes so need to call them up and get them replaced..
I fitted my new crank sensor.. Refitted the engine.. drive shafts fitted to make sure i had right ones these will be removed and my new CV joints fitted.. Fitted mk4 golf track rod ends as these are about 15mm or so longer so fit mk2 track rods with the mk3 hubs.. Fitted my new(used) metal coolant pipe.. Fitted the gear linkage to the box and all my gears engage fine..
Still need a clutch pipe  :angry: and a mk3 reservoir.. Once these come the brakes and clutch can be bled..
Tomorrow will see hopefully another day on the golf if the weather holds out.. I will try and sort some more engine bay stuff out and spend the day on wiring..
