Author Topic: Dan's mk2 8v to ABF project **Build For Le Mans??**  (Read 165286 times)
Offline tshirt2k
  • Been there...Done that...
Just realised mate. You need to change steering arms too. Probably for that reason.
Look here it's in the table.
Mk3 ABF 16VT Megasquirt V3
Offline lemski
  • 16v
U need mk4 track rod ends. I got em on my 2 with widetrack
Offline tech1889
  • Mk2 GTI FTW !!
So are they longer then so held on with more thread ???
Offline tech1889
  • Mk2 GTI FTW !!
Re: Dan's mk2 8v to ABF project *Now regularly updating*
« Reply #353 on: 29 June 2012, 20:23 »
Tomorrow is seeing a day spent on the little golf.. Pedal box and m/c here so will attempt fitting of that tomorrow as well.. m/c looks nearly new and is genuine VW which im happy with..
Also its going to get new kunifer brake lines from flexi's to my new 23mm m/c  :wink:
Lets hope the weather holds up !
Offline Neo Badness
  • Feet are for pedals
« Reply #354 on: 30 June 2012, 00:13 »
Sounds like a plan.
Your 23mm M/c where is the dimension that is different from the 22mm? Iirc it's the plunger? I bought a 23mm aaaaaages ago and never fitted and have vernier gauges now so just wanted to see if I'd been sold a lemon or not.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #355 on: 30 June 2012, 22:13 »
It's 23mm piston it's from seat Ibiza cupra iirc
Managed to get 3 metal brake lines fitted and run out of kunifer :(
Also the m/c has small ports one side and big the other so need some more unions :(
Two new front flexis genuine vw fitted for sum of £10 delivered :)
Offline Neo Badness
« Reply #356 on: 02 July 2012, 12:46 »
What I want to know is where is the 23mm vs 22mm?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #357 on: 07 July 2012, 15:32 »
I dont know to be totally honest mate just bought it... looks good and is stubby for if i ever go 1.8t..
More bits on their way..
Thermostat and o-ring... short flexi hose lines so i can finish the brakes off.... fuel filter.. and a few other little bits nothing exciting..
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #358 on: 07 September 2012, 20:47 »
Spent afternoon on the old girl today..
Removed boot plinth checked for rust there was none so replaced screws with stainless items..
Ran some more brake lines now have all new fronts.. The two long ones to rear..
Need to remove rear rubber flexis which are a pain and replace with my new ones.. And run short hard lines at the rear..
Going to maybe remove engine tomorrow and fit pedal box and cable shifter
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #359 on: 17 February 2013, 12:39 »
Pressure now on for the old girl.. Been off the road for just over 2 years.. Im going to Le Mans 24 in June this is my car registered to be taking..
The fight is on...
