Author Topic: Dan_GTi8v, 20vt project  (Read 129156 times)
Offline dazfx
Re: Dan_GTi8v, 20vt project
« Reply #200 on: 14 March 2012, 10:04 »
Dan one more question mate!
when converted yours did you change to mk4 clocks or keep the standard mk3
Ones?
Cheers bud
Daz
Offline Dan_GTi8v
« Reply #201 on: 14 March 2012, 21:31 »
Everything inside including clocks is standard mk3, though if running anything below a 16v/vr6 it may be a good idea to use their clocks for a higher speedo (not that I go over 140mph or anything  :wink:)
depending on the engine you use and the mk3 loom though some things may need changing, for example I have an AUM which is electronic throttle so I had to fit an electronic throttle pedal, also as mine was an 8v I had to change the 8v 020 rod gear change to a 16v 02a (soon to be 02j mk4) cable change and change the 8v cable clutch to a 16v hydraulic clutch, which is a pain in the arse! highly recommend starting with a valver!
with the loom if you have a lower spec mk3 and use a 16v loom for example you may have to add some stuff to the fusebox but afaik nothing is compulsory from the higher spec cars :)
hope you decide to go ahead with the conversion, nothing puts a smile on your face like a 20vt mk3  :evil:
Offline dazfx
« Reply #202 on: 14 March 2012, 23:08 »
thanks for the info dude. I have a 2.0 8v cabriolet, been doing my research so i know i gotta change the clutch over and maybe the throttle pedal but i'm willing to do that! :grin:
i would love to have a valver mate but really enjoying the cabriolet, so a 1.8t is going in it early next year just need to start gathering the parts!!
thanks again mate
dazfx
Offline Dan_GTi8v
« Reply #203 on: 14 March 2012, 23:23 »
20vt cab is gonna be my next project once i get my own garage to keep it in  :cool:
Offline Dan_GTi8v
« Reply #204 on: 26 May 2012, 20:23 »
I've been ever so slightly slacking in the recent months with updates mainly because I forget to take pictures or simply cant be arsed, but I managed to get a few the other day in the sun. Nothing much but its looking a bit different to last update
engine bay while I was doing a bit of tinkering
and how my gearstick looks with the 02j shifter before I out the knob on
next mission is removing the gti trim (again) and sorting out all the rust then refitting the cl trim, not sure what to do after that think im almost there
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #205 on: 27 May 2012, 01:13 »
looks good mate
like that porsche in the background  :cool:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Dan_GTi8v
« Reply #206 on: 29 May 2012, 22:16 »
cheers, yeah thats my Dads current mid life crisis motor, so far hes been through a Porsche carrera softtop, forget which model it was, a 52 plate audi TT, and now he has this, Porsche 911 Turbo 930  :cool: In the coming months that's going to be getting a new exhaust and rebuilt engine should be a beast when finished
Also has an MG BGT that we're restoring hopefully in time for le man classic in July, bodywork has been done enough to get the mot done, now it just needs the paintwork seeing to and hoping to rebuild the engine in time where it should put out around 130bhp. only 80 from standard so its quite an improvement especially in what is essentially a tin can on wheels!
On to my car then :P
Taken the arches off and fitted the CL trim, now have some horrible lines from where the arches have scratched the paintwork and a few rust bubbles. started fixing the rust today, not happy with the finish though so it will be redone sometime next week. Was fine up to the lacquer but the 2nd coat bubbled and my attempts to sort it out were a failure :(
Here are the pics I got today
Didn't get a before pic so this is a similar but smaller bubble on the other side
Engine bay, bit tidier and cleaner now :) still a work in progress though
Interior progress
Exterior, new indicators/fogs, smoked repeaters, black powder coated new beetle 16s, and the cause of my recurring nightmares, the exhaust that no matter what I do wont stop knocking! At least its hanging straight now though
That's it for now almost there :)
Offline murraymint
« Reply #207 on: 29 May 2012, 22:22 »
Looking good! Did you fit those rear seat mounts alright?
josh
Offline Dan_GTi8v
« Reply #208 on: 29 May 2012, 22:32 »
No I didn't mate :( Only tried to fit them last week but they are too long I can only guess that there are different types of mk4 mounts? No big deal though I can cut them down and re-weld they are the right shape and everything just too long. Thinking I'm gonna leave it for now though as I'll eventually get a leather mk4 interior and knowing my luck I'll cut the mounts down then they will be too short for the leathers  :grin:
Offline tshirt2k
  • Been there...Done that...
« Reply #209 on: 29 May 2012, 22:37 »
What exhaust is it?
Mk3 ABF 16VT Megasquirt V3
