Author Topic: Daylight running lights and xenons.  (Read 41737 times)
Offline daviescotland
Re: Daylight running lights and xenons.
« Reply #40 on: 03 April 2010, 14:02 »
I have a mk6 GTI with xenons.
The car came from my dealer (240 miles away) with the DRL set to have the headlights and rear lights on. So its basically got dipped beam on all the time.
So it looks like to every other person on the road like i have my lights on all the time even in bright sunlight! :sad: This is now really getting on my moobs.
Anyone know what settings to change in VAGcom?
I have tried the DRL turn of sequence as listed on forums and in the manual but it does not work in my cars settings case i guess because the dealer has set something different up.
Help + 1  please :sad:
I may be making a trip to that dealer my dad knows in the next few weeks to see if anything can be done
Me too. But looking at all the different responses it looks like they CANT be turned off (xenons only) nightmare!!!
MK6 GTI, 3 door, candy white, 18" monza shadow, Xenons, RCD 510 w "dynaudio", sunroof, rear view camera, cruise control & free servicing.
Ordered 28/10/2009. BW07 confirmed. production complete 10/02/2010. Arrived at dealers 17/02/2010. Driving on a 10 plate 01/03/2010.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #41 on: 03 April 2010, 14:05 »
I could prob put up with the xenons been on,  its that i also have the back lights on too.
 I now actually drive about with side lights on as its the only option i have over having them all on :grin:
Garage:
35+ years of GTI ownership.
« Reply #42 on: 03 April 2010, 14:14 »
Totally agree with you snoopy. I actually think the sidelights look not too bad. Hate people thinking i'm driving around with my xenons switched on for show......  :smiley:
Offline H12
« Reply #43 on: 03 April 2010, 20:22 »
With you as well on that.. I saw a load of new golfs on the M1 today and probably 90% + had their lights on- it just looks so wrong. Does anyone know on average how long xenons last if they're on all the time ?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #44 on: 03 April 2010, 20:38 »
Have a look on this link scroll down
to instrument got all the codes etc
http://en.openobd.org/vw/golf_1k.htm#09
H12 I wonder if we have
Byte 00 Bit 3 Daytime Running Lights (Scandinavia) activated or
Byte 17 Bit 4 Daylight Running Light with dimmed Low Beam
Garage:
Offline GolfTi
  • ..gotta feel for my automobile..
« Reply #45 on: 03 April 2010, 20:52 »
For those of you old enough to remember...
DRLs remind me of Jasper Carrott's classic Volvo joke.
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #46 on: 04 April 2010, 11:20 »
Now if i only had my insurance sorted DOH!  :embarassed:
I would see if sundaydriver was free to see if we could set this up differently,
Especially as he said he is coming to my neck of the woods to my local dealer for a look at the VWR wheels.
DOH!
http://forums.vwvortex.com/zerothread?id=4743553&page=1
VAGCOM
These instructions apply to Golf 6 platform vehicles including the Golf and Jetta. Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk.
It is always recommended to perform a complete Auto-Scan and save it prior to coding changes. Please see the Online Demo / Manual: Auto Scan Screen
Address 09 - Central Electronics:
If this module does not communicate, unlock all vehicle doors and try again.
Windows up via remote
Comfort Operation (via Remote Control) found in Adaptation. From the drop down list, choose 1 (On) and Save.
Daytime Running Lights are found in Coding, Long Coding helper, the lamp systems are different:
- Factory Xenon – Byte 11
- Factory Halogen – Byte 15
Cornering Lights via Front Fog Lights active are found in Coding, Long Coding helper
Fogs as Daytime Running Lights Tested on Xenon equipped vehicles
Fogs only
Byte 11 - un-check "Daytime Running Lights (via Low Beam) active"
Byte 14, Bit 1 - Manually modify the binary value from a "0" to a "1"
Fogs and Xenon Headlights as DRLs at the same time
Byte 11 - leave this alone
Fogs as Daytime Running Lights suggestion for Halogen equipped vehicles, NOT TESTED
If this is successful on Halogen vehicles please update this thread.
Disable Factory Halogen DRL's in Byte 15 - un-check "Daytime Running Lights (via separate lights) active"
Alarm Confirmation via lights and horn
Found in Coding, Long Coding helper.
Comfort Turn signals
Found in Adaptation. From the drop down list, choose the number of flashes and Save.
Emergency Brake Warning active
This actually uses the 4 ways flashers, not a flashing of the brake lamps.
Auto-Lock
Coming Home
If the vehicle is not equipped with an "Auto" headlight switch, coming home activation will likely require you to pull the high beam
stalk back briefly after shutting the vehicle off and before exiting. The description should be found in your owners manual.
Leaving Home
Leaving home will likely require the "Auto" switch and a light sensor. The description should be found in your owners manual.
Address 08 – Auto HVAC:
Drivers heated seat memory
Found in Adaptation. From the drop down list, choose Storage of seat heater level driver. Change to On and Save.
This may not be supported on all control modules.
Address 17 – Instruments:
Staging feedback here:
MkVI Instrument cluster - which one do you have?
Please update that thread with your info. It looks like 5K6 920 870 D and 5K6 920 970 H will activate.
Retrofits:
NAR Vehicle, European switch retrofit:
DIY - Wiring a Euro Headlight Switch to run parking lights
NAR Golf / Gti LED Tail Light retrofit:
In progress...
LED tail lights
You need vagcom to reprogram. I´m sure your lokal dealer can help you.
Set your new code in BYTE 18 to:
Byte 18 Bit 2
04 = 00000100
I´m not sure this will make you remove your errors, because cars whitout xenon and prductionsweek before week 45 2009 has a different software. This software can not be reprogrammed, need to change your hardware BCM.
Maybee you can find an answer in this thread
Speedo needles
VCDS Version 912 beta
Select under 17 Instruments -> 10 adaption -> Staging
and activate.
Thats it.
« Last Edit: 04 April 2010, 11:45 by Snoopy »
Garage:
Offline mac7
« Reply #47 on: 04 April 2010, 16:19 »
I thought the xenons had to be switched on all the time so that you are able to flash your high beam?
Golf R
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #48 on: 04 April 2010, 18:38 »
Never had to for the lupo GTIs back in the day iirc :undecided:
Garage:
Offline p3eps
« Reply #49 on: 04 April 2010, 20:46 »
My ED30 had xenons, and flashed the full beam no probs without the xenons being on.
I don't think the full beam was xenon though  :undecided:
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
