Author Topic: Daylight running lights and xenons.  (Read 41739 times)
Offline mac7
Re: Daylight running lights and xenons.
« Reply #50 on: 05 April 2010, 11:29 »
That's what I mean - other cars have a halogen high beam bulb somewhere (inner lamps on the Mk5 for example) as well as the xenon. The Mk6 doesn't, it just uses the xenon lamp with a shutter for high beam. The inner lamp is an indicator only. As a high voltage xenon lamp takes a few seconds to power up, you can't use it just to quickly flash your headlamps unless it is on all the time... I haven't had a play with a Mk6 yet though to confirm this though.
Golf R
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #51 on: 05 April 2010, 12:09 »
The Lupo GTI only had the one iirc.
Garage:
35+ years of GTI ownership.
Offline H12
« Reply #52 on: 05 April 2010, 18:42 »
Have a look on this link scroll down
to instrument got all the codes etc
http://en.openobd.org/vw/golf_1k.htm#09
H12 I wonder if we have
Byte 00 Bit 3 Daytime Running Lights (Scandinavia) activated or
Byte 17 Bit 4 Daylight Running Light with dimmed Low Beam
Sounds like you may be right there, mate. I hope to go to that dealer I spoke about next weekend if I can so will let you know how I get on..
Offline p3eps
« Reply #53 on: 05 April 2010, 18:50 »
Snoopy... did you carry on with the Skoda Vagcom group buy, or did you pull out with the VAT increase?
I pulled out and went to MI - where I got it for £250... cable, carry case, manual & disk.
Not the bargain I was hoping for, but good fun to play with!
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #54 on: 05 April 2010, 18:59 »
I pulled out as i thought were you got yours i fancied the case. But i have been thinking of buying the complete set so i can do the older audis and VW too as a few mates run older cars.
Garage:
Offline p3eps
« Reply #55 on: 05 April 2010, 19:05 »
The case is a simple plastic shell with a bit of foam in it.  Nothing special, but I guess it saves the cable lying around and getting lost!
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #56 on: 05 April 2010, 19:13 »
Im more worried about my cat chewing it  :grin: She likes to chew cables. :shocked:
Also keep it from getting lost.
The subject of xenons and main beam flash.
First thing this morning i went to the car and got in. Without turning anything on,
I pulled the mainbeam stalk to flash the xenons. CLUNK and we have bright light. Let go of stalk CLUNK.
So it works fine.
Please do i want mine off.
« Last Edit: 05 April 2010, 19:15 by Snoopy »
Garage:
Offline mac7
« Reply #57 on: 06 April 2010, 18:38 »
So it works fine.
Good to know. That means I can run just the LED's on the front of the R. Nice to have a good old fashioned low-tec CLUNK as well  :grin:
Golf R
Offline H12
« Reply #58 on: 12 April 2010, 19:08 »
I didn't manage to see the VW dealership last weekend but my dad spoke to his mate there regarding de-activating the dipped beam and tail lights in day light running mode. They need to know the chassis number to see whether they can be switched off or not- if they can, they cannot be switched on again, apparently.
The guy also mentioned the old chestnut about the new EU regulations saying that all new cars after a certain date will need to have daytime running lights on otherwise you'll be breaking the law. That seems to be a topic for debate here as some people reckon it's only for new cars built after the specified date ?
I've managed to get the name of another guy at my dealer so have just sent him a quick email to see what he says...
Offline mac7
« Reply #59 on: 12 April 2010, 19:17 »
Yep, but only for new cars registered after January 1st 2011. If you get your car on the road before that, you can turn them off and not have a potential problem with Mr Plod.
Golf R
