Author Topic: Wierd feeling coming from the front  (Read 4596 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
« on: 28 August 2008, 18:36 »
Well it seems my luck hasnt lasted long. My golf seems to be making a clunking noise when going round a bend and then when you get straight it seems to make a weiring noise that then goes away.
Mate said to check bottom arms which i have done and cant find any movement/play in them. Also when i spin the wheel back and forth with not much travel there seems to be abit of play.
Any idea's on what this could be?
Offline Hulmie
Re: Wierd feeling coming from the front
« Reply #1 on: 28 August 2008, 20:20 »
after having a good route around it seems that i need to replace the passenger side Driveshaft as there is play coming from it when rotating the disc. So only had the car 2 weeks and already something has gone wrong, brings back memories of the calibra.
Offline richw911
« Reply #2 on: 28 August 2008, 21:24 »
Wheel bearing? if it is it will be loud when you turn?
*cough* someone say vauxhall!! *cough*  :grin:
Offline bobbarley
  • I'm kind of a big deal...
« Reply #3 on: 28 August 2008, 21:25 »
Might have a Polish person hiding in there!!
Offline Hulmie
« Reply #4 on: 29 August 2008, 16:00 »
it seems like the wheel is vibrating when going round a bend and in a straight line.
Offline Rhyso
« Reply #5 on: 29 August 2008, 16:08 »
wheels fully balanced?  :undecided:
Offline Hulmie
« Reply #6 on: 29 August 2008, 16:32 »
yeh wheels are fine mate as it drove back from north wales ok which is a 2 hour 30 min drive. Only started the other day when i moved forward it a queue and heard a clunk and felt it in the car, then got worse and now you can feel it when driving.
Offline Rhyso
« Reply #7 on: 29 August 2008, 16:36 »
springs ok?
i had one snap the other month - drove ok in a straight line but clunked when turning
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« Reply #8 on: 29 August 2008, 16:52 »
i hav a clonkin noise on full lock right hand down only   :cry: its has come bk had it lst year when it went in 4 mot my drive shaft was loss so just check that.
where about in north wales where u i live there.
Offline Hulmie
« Reply #9 on: 29 August 2008, 17:19 »
I live in Lincolnshire mate, bought the car from North Wales near Greenfield. Which side did your driveshaft come lose at? was it gearbox end or hub end?
Also can someone tell me the size of the NUT that holds the shaft in the HUB, is it a 30mm?
