Author Topic: Wierd feeling coming from the front  (Read 4594 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
Re: Wierd feeling coming from the front
« Reply #10 on: 29 August 2008, 17:31 »
I live in Lincolnshire mate, bought the car from North Wales near Greenfield. Which side did your driveshaft come lose at? was it gearbox end or hub end?
Also can someone tell me the size of the NUT that holds the shaft in the HUB, is it a 30mm?
no way thats where i live greenfield never seen that car around here o well.
gearbox side m8
Offline andy_vdub
« Reply #11 on: 29 August 2008, 17:34 »
not speaking from a vw point of view as i know bugger all about vw's but i had a similar thing happen on one of my hondas.
I think your right with the driveshaft, mine turned out to be the bearings, failing that it could be a cv joint
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #12 on: 29 August 2008, 17:59 »
was it the allen key bolts that came lose at the gearbox side?
The car used to have audi wheels and bonnet Bra. Only bought it 2 weeks ago mate
Offline (shakey)
« Reply #13 on: 29 August 2008, 18:06 »
the allen key 1s m8.
i know i seen it on pistonheads a while bk nice car :cool:
Offline Hulmie
« Reply #14 on: 29 August 2008, 18:07 »
yeh thats the car mate. Got it for a bargin, but maybe now im finding out why it was cheap.
Offline (shakey)
« Reply #15 on: 29 August 2008, 18:11 »
what did u pay 4 it if u dnt mined me askin its not a big problem with the car so i wudnt worry m8 i know u only got 2 wks ago but it cud of happened on the first then u wud of been gutted.
Offline Hulmie
« Reply #16 on: 30 August 2008, 13:06 »
car stands me at £2350 mate, which is a real bargin.
The fault on my car seems to be the N/S CV joint, has alot of play in it. Is this a common fault with Golf's?
Offline (shakey)
« Reply #17 on: 30 August 2008, 15:07 »
what a bargin m8 not to sure
Offline Hulmie
« Reply #18 on: 30 August 2008, 19:02 »
been struggling to get the bottom arm seperated from the suspension leg, do you have to remove the bottom ball joint completley or can you just prise the bottom arm down to get the ball joint out?
Offline Hulmie
« Reply #19 on: 01 September 2008, 17:05 »
Can someone help me with the above question, need to get me car back on the road as i miss driving it
