Author Topic: Wierd feeling coming from the front  (Read 4593 times)
Offline Rhyso
Re: Wierd feeling coming from the front
« Reply #20 on: 01 September 2008, 17:07 »
Can someone help me with the above question, need to get me car back on the road as i miss driving it
think the bottom ball joint is held on with 3 bolts mate
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #21 on: 01 September 2008, 19:36 »
yeh thats right, but do i need to undo these to get the bottom arm off the suspension leg to remove the drive shaft or can the arm be levered down?
Offline Hulmie
« Reply #22 on: 03 September 2008, 17:45 »
found out yesterday that the problem was not CV joint or driveshaft. The fault seems to be down to the Coilover losing its gas and therefore not returning to its proper position after going over a bump. This then is causing the wheels to vibrate. So rather than a cheap fix of £40 its costing me £200+ for a full coilover kit.
Offline Hulmie
« Reply #23 on: 04 October 2008, 10:34 »
It seems i dont have any luck, after fitting the new coilovers on the front the noise and wheel vibration went away, but after about 3 weeks it has come back and is doing the same thing again. Going to me mates garage this morning to have a look at it, damper still seems to be doing its job, but can see the wheel vibrating/juddering when moving back and forth slowly. Im hoping we can find the fault and finally put a end to the problem. If not may look at selling the car, which i dont really want to do.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #24 on: 04 October 2008, 14:33 »
I don't see the point in doing that.......  Your next car could be worse!!  I'm sure your mate will get to the bottom of it, & it will be all smiles again. I know it's depressing, ATM (I'm getting frustrated with mine, too!), but when she's running sweet again, you'll be glad you kept her! :afro:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline richw911
« Reply #25 on: 04 October 2008, 19:45 »
Too true  :wink:
Offline Hulmie
« Reply #26 on: 06 October 2008, 17:22 »
well went to the garage on saturday and couldnt pin point the fault or any idea of what is causing it. Going to another mates this week to get a second opinion. He seems to think that the new suspension will be ok as it is still rebounding fine and there is no sign's off leakage. He thinks maybe the bottom arm or ball joint could be the cause. Still very strange why it would cause the wheel to vibrate/judder.
Oh well back to the drawing board, will be putting my plans to sort the bodywork, detail the engine and get a different remap on hold until i get the problem sorted. Oh and Tax the end of the month, best make sure i get that.
Offline richw911
« Reply #27 on: 06 October 2008, 18:47 »
Unevan tyer wear?
http://www.golfgtiforum.co.uk/index.php?topic=92328.0
Offline Hulmie
« Reply #28 on: 08 October 2008, 16:54 »
thanks, but the tyres are fine make and it wouldnt cause the wheel to vibrate when moving slowly. Ideally im gonna try get me mate to take a video of it on his phone so i can show whats happening.
Offline Hulmie
« Reply #29 on: 08 October 2008, 21:32 »
just read a post about Poly dog mount bushes. With my car having poly dog mount bush could this be causing vibration down the driveshaft to the wheel?
