Author Topic: Headliner now in pics  (Read 5010 times)
Offline Vdubbster
« on: 17 April 2008, 19:32 »
So I attempted to re-trim my headliner last month. It went bad  :laugh:
I have just got hold of another headliner and pillars so the fun has started again  :huh:
First I have pulled the old stuff off
Then got wire brush to take off the foam
Expanding foam in the handle recesses, messy stuff
Sawed the foam down and used filler to get them all flush, used the filler to repair some small dents and weaker patches of the liner
Done this in satin black
This time round I am going to use a brush-on adhesive glue, cant be arsed with spray stuff.
Im thinking of using acoustic carpet as its stretchy and thick, so glue shouldnt seep through, what you reckon?
« Last Edit: 03 May 2008, 13:32 by Vdubbster »
Offline nelds
  • Now Golfless but owning an Audi still counts
Re: Headliner (again)
« Reply #1 on: 18 April 2008, 06:58 »
i finally done my lining, started to sag a little but htats cos i ran out of glue and rushed it. i like your idea of deleting the grab handles, should make it easier to cover with no tricky corners to do now. i like wot you did with switch, i've left mine grey for now along with the sunroof piping. just taking ages because i have no time.
Offline barry-gti
« Reply #2 on: 18 April 2008, 08:43 »
i want my roof lining black, can i jus paint it whilst its in the car, im ging to do the pillars aswell but i will take them out. just fort it might be easier to leave the headlining in and save problems??
Offline bored_Welsh_lad
« Reply #3 on: 18 April 2008, 09:06 »
nah mate, you will have to pull it out... covering it isnt hard if you get the right material...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline barry-gti
« Reply #4 on: 18 April 2008, 12:23 »
u can spray it tho cant you??
« Reply #5 on: 18 April 2008, 13:14 »
not really mate, its material and would crap sprayed tbh...
Bumper Vents :D
Offline Vdubbster
« Reply #6 on: 18 April 2008, 14:07 »
I tried to paint old one, NOT good results
Offline nelds
« Reply #7 on: 18 April 2008, 20:44 »
i've sprayed my sunroof slide cover, sun visors and grab handles (wish i'd thought to delete mine tho)  but covered the lining in suede. I took all pillars plastic out and wrapped those in suede too. run out of material and need to get some more to finish rear panels.
Offline Pete Taylor
« Reply #8 on: 18 April 2008, 23:07 »
The screws that hold on the grab handles are one of the main things that hold the lining to the roof, could give you some issues there
Offline Vdubbster
« Reply #9 on: 19 April 2008, 00:01 »
I was thinking this also, Im hoping all the rear pillars will do enough to hold it all up. The sunfroof will hold the front, just the rear.
Early passats have black grabs which will fit, and the cabrio has black visors also
