Author Topic: Headliner now in pics  (Read 5006 times)
Offline Vdubbster
Re: Headliner (again)
« Reply #10 on: 24 April 2008, 12:10 »
Done the sunroof cover, used acoustic carpet and paint on adhesive. the thick carpet don't let any glue through
Just the bloody headliner now
Offline nelds
  • Now Golfless but owning an Audi still counts
« Reply #11 on: 27 April 2008, 14:55 »
how much for the acoustic carpet...??..and hwere you get the glue/what make ??..the black suede on my headlining keeps bloody sagging..!!!......fooking thing! cant use too much glue because it soaks thru.
Offline Vdubbster
« Reply #12 on: 27 April 2008, 18:17 »
Ok, its done, THANK CUFK FOR THAT
Acoustic was from ebay, everywhere else seemed to do 1X2 meters, I got 1.4 X 3M for £25.
The glue I went for in the end was evo Stick Adhesive from Wilkinson's, this stuff is perfect, brushed it on both the headliner and carpet, left it for about 10 - 15 minutes then pushed them both together.
This carpet is wicked, It gave me no problems with creasing, so easy to lay as long as you let the glue set. This is the most important thing!
Its took a while as I did a section at a time.
Here some pics now done, just needs fitting.
Here where the visors go I had to be careful and take my time, managed to get the carpet stretched in all recesses nearly perfectly. The glue needs to be tacky here before applying carpet.
Used super glue to tidy up the rear, super glue does soak through so had to be careful.
Il get some pics up once its in the car
« Last Edit: 27 April 2008, 18:20 by Vdubbster »
Offline eightyeightmph
Re: Headliner NOW DONE :-)
« Reply #13 on: 27 April 2008, 18:32 »
Looks like you've done a good job there mate!
I used evo contact when I was recarpeting Beetles, great stuff & as you say needs to be left to go tacky before you push surfaces together!
Interested to see what it looks like all fitted up! :smiley:
2016 GOLF GTD
Offline golfmk31993
« Reply #14 on: 27 April 2008, 18:41 »
u should get some of the vr6 highline black pillar plastics, they would suit it really well :cool:
Offline nelds
« Reply #15 on: 28 April 2008, 08:19 »
let me know how it holds in place without the grab handles, if its any good im gonna lose mine too (even tho i have sprayed them black) did u spray your visors..??
Offline Vdubbster
« Reply #16 on: 28 April 2008, 11:05 »
Not done visors yet, how do yours look?
And what did you do with that rubber around the sunroof?
Offline nelds
« Reply #17 on: 28 April 2008, 22:36 »
i'll try and get some pictures of my visors. they look ok apart from it's rubbed off the bit that clips in, i might put black tape over that part. the trim around sunroof is still grey, i started to remove it then changed my mind. doesnt look to bad being grey cos i still have grey sunroof switches
Offline ToRo
  • Just because I won't - doesn't mean I can't.
« Reply #18 on: 28 April 2008, 22:48 »
Sweet! I want mine black, and now I know how :D
Dunno why they didn't do it anyway, looks silly cream/grey with everything else black lol!
Offline Mikester
  • Civic Type R
« Reply #19 on: 29 April 2008, 00:50 »
i really want to do this too, just its one of those jobs thats such an effort!
