Author Topic: Headliner now in pics  (Read 5005 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: Headliner NOW DONE :-)
« Reply #20 on: 29 April 2008, 01:41 »
ditto mikester, but got too much to do already, cant even think of doing it yet. Although i might look around for black handles and visors, etc.
LL ;)
Offline Vdubbster
« Reply #21 on: 29 April 2008, 14:44 »
Well this was the second attempt, and I am happy with it.
First time was a right Fcku UP and I hated looking at the damn thing, as soon as the weathers better il fit it in.
Glad its done as Ive got GTA4 to mess about with for a while :-)
Offline Vdubbster
Re: Headliner now in pics
« Reply #22 on: 03 May 2008, 13:35 »
Ok so I put it all back in today, took the piss
anyway heres a couple a pics, just need black visors
Offline ToRo
  • Just because I won't - doesn't mean I can't.
« Reply #23 on: 03 May 2008, 14:55 »
Looks real smart that! Good job!
Offline nelds
  • Now Golfless but owning an Audi still counts
« Reply #24 on: 03 May 2008, 20:17 »
what finish did u decide on with the trims in the end..?.......did u spray the  sunroof surround..? was it a b!tch to get it back on. also (last question, honest  :grin: ) does it hold up ok without the grab handles
Offline alcamistdvd
« Reply #25 on: 03 May 2008, 20:40 »
ditto to all those as i'm thinking of doing the same
al
Offline nelds
« Reply #26 on: 03 May 2008, 22:28 »
i'm gonna leave my door pillars black suede and just hope they'll look OK with the acoustic carpet, spent too long on them to change them now. can  u send the link from the buyer u used on fleabay.
Offline Vdubbster
« Reply #27 on: 04 May 2008, 01:43 »
Ok,
The rubber around the sunroof was sprayed with matt black, it took ages to dry. I put it back on the car and used a clothes line to fit the headliner back in (you know the method to fit windows with older seals, like mk2 golfs have?) This carpet is thick so the sunroof requires a litle more force, however the electric sunroof still moves it fine,
These trims are all gloss black, I have another set though ready for painting matt black to match the original black trim. Gloss looks CR*P
The headliner was SO annoying to fit, you need at least two people. I put it through the boot and used the rear trim panel to hold it in place at the rear, GF was holding it up from the front while i used the clothes line to fit the sunroof rubber. This entire job needs lots of time, so allow for it.
In relation to the handles, its holding up fine. the sunroof holds the front half up great, the rear is ok, however I think it may be worth fitting the rear handles to be sure. acoustic carpet should be able to fit in the handle recesses without creasing!!
If you dont have a sunroof you should USE your grab handles!
when you put the carpet on the headliner, take your time and do it in stages! if you use the impact adhesive as i did get plenty on the headliner and a little on the back of the carpet AND ALLOW IT TO GO TACKY!
Ebay seller - wercarmats he supplied me 1.4 X 2.5 meters of this stuff for £25 delivered, came the following day A*
Nelds, you could use that suede on the sunroof so your panels match + the sunroof will move more freely :-)
Offline nelds
« Reply #28 on: 10 May 2008, 22:03 »
stupid friggin job !!......the suede on my headlining is sagging, the hot weather has fooked the glue and the material has come away. looks like i'll be getting the acoustic carpet after all !
Offline Vdubbster
« Reply #29 on: 10 May 2008, 22:29 »
Ive been checking mine with this sun and its fine, go for the brush adhesive as I did, form wilkos get two tins. 250ml each
