Author Topic: Wheel Arch or spare wheel build?  (Read 4767 times)
Offline lordbigsack
« on: 02 April 2008, 13:47 »
I am looking to build a sub enclosure in the boot of my MkII but cant decide between the rear wheel arch or a spare wheel well build.  What are the thoughts on this.
Also, where is the best (for best, read cheapest) place to get the glass fibre matting and resins.
Scott
Things I need (Mar 08): 1990 Drivers door in calypso green for 3door - someone must have one!
Things I have found: (Mar 08)Power steering pump bracket, sun visor clip
Offline Len
Re: Wheel Arch or spare wheel build?
« Reply #1 on: 02 April 2008, 15:02 »
Wheel well is easiest but loses you boot space and usability.
Wheel arch is harder to do but leaves boot clear.
Halfords large repair kit as you get gloves and pot/stirrer.
www.sas.org.uk
www.the-ace.org.uk
Offline Hurdy
« Reply #2 on: 02 April 2008, 23:58 »
I did an arch build in my MKV. The fibre-glass and resin packs were the biggest outlay as I just bought them from Halfords. All-in-all it cost around £100 for all the stuff.
I would have thought that the arch in the MKII is much smaller than the MKV and that the wheel well is for a full size tyre in the MKII, so I'd probably opt for the well rather than the arch. Same principle though.
http://www.golfgtiforum.co.uk/index.php?topic=81119.0
Seat Leon Cupra Black 290 DSG
Offline lordbigsack
« Reply #3 on: 03 April 2008, 13:58 »
cheers for the info, the write up has helped no-end.  Think I am going to go for the Wheel arch, think it just looks more robust than having the sub in the spare wheel well.  How does the box perform?  do you get a good sound from it.
Just need to find a cheap fibre glass supplier near York!
Offline Len
« Reply #4 on: 03 April 2008, 14:06 »
Mine is great even form a 10" sub.
www.sas.org.uk
www.the-ace.org.uk
Offline leeroy20vt
  • h reg mk2 gti
« Reply #5 on: 03 April 2008, 18:52 »
thats very intresting that write just 1 question how do u do the maths to work out how much air is in there
Offline lordbigsack
« Reply #6 on: 03 April 2008, 20:35 »
I guess you could fill it with water once you have the basic tub, that should give you the volume and adjust it from there to get the exact amount.
are these good prices for matting and resin?  http://www.polyfibre.co.uk/
Offline Len
« Reply #7 on: 03 April 2008, 20:42 »
From my surfboard making days I'd say those prices are very good.
Good find mate!
www.sas.org.uk
www.the-ace.org.uk
Offline lordbigsack
« Reply #8 on: 03 April 2008, 21:46 »
Any ideas which bits/parts/quantities I would need to make the box.
Len,  What type and how much gear did you use?
Ta,
Scott
Offline Hurdy
« Reply #9 on: 03 April 2008, 23:31 »
Sound if anything is better than when it was in the MDF box :cool:
