Author Topic: Wheel Arch or spare wheel build?  (Read 4681 times)
Offline Hurdy
Re: Wheel Arch or spare wheel build?
« Reply #10 on: 03 April 2008, 23:34 »
thats very intresting that write just 1 question how do u do the maths to work out how much air is in there
Filled the fibreglass mould with water and then calculated the shortage as a basic rectangle x depth which worked out at around another 30mm build up on top. Took off the reduction in space that the sub would take up in volume and voila. :nerd:
Seat Leon Cupra Black 290 DSG
Offline leeroy20vt
  • h reg mk2 gti
« Reply #11 on: 04 April 2008, 20:32 »
cool cheers fella
any 1 seen this done in a mk4
Offline Len
« Reply #12 on: 04 April 2008, 21:03 »
Any ideas which bits/parts/quantities I would need to make the box.
Len,  What type and how much gear did you use?
Ta,
Scott
I would go for a 5ltr of resin to be safe, with the requisite hardner.
Matting - well go for a medium as you may want to bend it and the heavy ones wont!
I would still look at putting some plywood or MDF in there as stiffening where you can, but thats up to you.
www.sas.org.uk
www.the-ace.org.uk
Offline lordbigsack
« Reply #13 on: 07 April 2008, 13:28 »
Cheers for that, I am gonna get it ordered in the next few days.
Do you need to put any wadding or acoustic material inside the box to avoid echoing or distortion?
cheers,
Scott
Things I need (Mar 08): 1990 Drivers door in calypso green for 3door - someone must have one!
Things I have found: (Mar 08)Power steering pump bracket, sun visor clip
Offline Ben Lessani
« Reply #14 on: 09 April 2008, 17:53 »
Argh, don't buy from Halfords £Â£Ã‚£ - for their £20 kit, I could get it for you for £4 for Maccess! And even still, its crappy - steer clear of any F/G that uses pink paste as hardener, MEKP is much better.
These guys are very well priced, http://www.allscotltd.co.uk/ . Half of the boatyards up here use them as a supplier!
http://www.talkaudio.co.uk/vbb/showthread.php?t=76606
