Author Topic: Do you know what cable it is?  (Read 2997 times)
Offline Khare
  • The bear that khares
« on: 02 March 2008, 22:54 »
Whilst doing my daily engine check up :rolleyes: i found a brown cable that goes from the engine head but its not attached to anything on the other end. It finishes in a round kind of shape. Do you know what this could be? maybe oil related, cos the oil light flashes when the ignition is turned on and my oil level is full, filled it up last week.
Offline Diamond Hell
  • Opinions я Us
Re: Do you know what cable it is?
« Reply #1 on: 03 March 2008, 11:55 »
Brown cable, with a ring end says earth all day long.
A photo might help people here.
Offline kittie
« Reply #2 on: 03 March 2008, 11:57 »
The oil light normally flashes when you turn the ignition on before you start the engine, doesn't it?
Offline Uruk Hai
« Reply #3 on: 03 March 2008, 12:30 »
It does and then obviously should go out after a second or two, does sound like an earth wire though. Pictures needed realy as me crystal ball has a bit of a miss fire today  :wink: :wink: :grin: :grin:
Offline Jay
  • balding fat cvnt
« Reply #4 on: 03 March 2008, 13:50 »
It does and then obviously should go out after a second or two, does sound like an earth wire though. Pictures needed realy as me crystal Headlights has a bit of a miss fire today  :wink: :wink: :grin: :grin:
Offline MeTsU
« Reply #5 on: 03 March 2008, 16:50 »
Certainly does sound like an earth wire.
Matteo Casale - +27 73  257 9368
'92 Mk2 GTi 2.0 16V Exec.
Offline Khare
« Reply #6 on: 03 March 2008, 17:10 »
This is the "mystery wire"
Offline tobz.
« Reply #7 on: 03 March 2008, 17:22 »
That should most likely be connected to the carburettor, this makes sure the carb is earthed and therefore reduces the risk of the carb becoming live and then a spark being caused (not desirable for obvious reasons). This is needed as the carb is mounted on a rubber block and therefore doesn't have any other explicit earth connection.
You got any pics of your dad's split ?
Offline MeTsU
« Reply #8 on: 03 March 2008, 17:36 »
Hit the nail right on the head.  :)  Certainly not a good idea to have dodgy earth's.  Not only for that reason, but bad earth's are a common cause of power issues.  You can gain valuable HP from fitting a decent make grounding kit.
Offline Khare
« Reply #9 on: 03 March 2008, 18:11 »
so what are you saying? that i have to connect this to my carb and get a decent wire? the wire is badly peeled and worn.
