Author Topic: Do you know what cable it is?  (Read 2978 times)
Offline Jay
  • balding fat cvnt
Re: Do you know what cable it is?
« Reply #10 on: 03 March 2008, 21:44 »
Defo get another wire if it is worn badly, shouldn't cost much at all or if you feel like it, buy plain wire of the same grade and make it yourself  :smiley:
Offline Khare
  • The bear that khares
« Reply #11 on: 03 March 2008, 21:50 »
where do I have to connect it to then? i dnt know what part of the carb it goes into. I got a weber 32/34. any pics would help, if not edit one of my pics that shows the carb and using paint draw an arrow or circle to point out where the wire has to go.
Andres
Offline MeTsU
« Reply #12 on: 03 March 2008, 23:34 »
I reckon your easiest bet, is to source another cable, of similar grade and fit new ring fittings to it.  Keeping the one on the tappet cover where it is, just clean the area and then scrub the area of contact with a wire brush.  The other larger ring fitting fit on top of the mounting bolt for the carb, using another nut to secure it.  Just ensure all contacts are cleaned and then scrubber with a wire brush to ensure a good "connection".
It would be a good idea to go over all your grounding points and do this.  :)
Here is an example of a good grounding kit that you can buy.  I took the time to make mine, using decent 8 and 4 guage power cabling for sound systems.
Hope this helps.  ;)
Matteo Casale - +27 73  257 9368
'92 Mk2 GTi 2.0 16V Exec.
Offline Khare
« Reply #13 on: 04 March 2008, 10:05 »
cheers buddy. i'l givi it a go at making my own wiring set.  :smiley:
Offline MeTsU
« Reply #14 on: 04 March 2008, 10:10 »
For sure, not a problem.  :)  I'm sure you'll come right.
Offline Khare
« Reply #15 on: 04 March 2008, 12:50 »
quick question. what grade is the earth cable?? what would i have to ask for in a warehouse to buy it?
Offline Organisys
  • Old and Slow...
« Reply #16 on: 04 March 2008, 12:54 »
Whilst doing my daily engine check up
Bloody hell. Don't think I've lifted the bonnet on my daily for about 3 months.
Offline Khare
« Reply #17 on: 04 March 2008, 14:50 »
i dnt have to lift up everyday. but i just love my car. :grin:
Offline MeTsU
« Reply #18 on: 04 March 2008, 15:55 »
Try get hold of some 8 gauge cabling.  It's a common sized use on entry level sound systems.
Offline Uruk Hai
« Reply #19 on: 04 March 2008, 19:26 »
The sort of owner every old Golf needs  :wink:
