Author Topic: electric mirrors  (Read 8641 times)
Blue MK2
Re:electric mirrors
« Reply #20 on: 22 January 2004, 12:07 »
cheers Dizzy.
Ive just recieved the mirrors. I know that the brown is earth, the green/white is the switch and the black/yellow is the (+)
what about the other wires? They arent cut wires but have connectors on either sides of them on the mirror loom.
should i worry about these?
im guessing that some connectors on the loom go behind the fusebox ???
Re:electric mirrors
« Reply #21 on: 22 January 2004, 13:30 »
I think what you should have is 2 6 pin connectors on either mirror loom, these are joined together with another loom that goes inside the car between the 2 holes in the doors, and has 3 wires that connect inside the car, an earth a live and the wire that connects to the heated rear window switch:
                        |----------1
                        |----------2
                        |----------3
[] = mirror
* = 6 pin connector
1 = live wire
2 = earth wire
3 = heated glass wire
My 'full loom' only came with 1x 6 pin connector for the drivers side, the passenger side was just cut and I have no loom from inside the car!
Offline Dizzie
  • Make friends with your fast
Re:electric mirrors
« Reply #22 on: 22 January 2004, 16:17 »
there's a black and a white 3 pin connector for each mirror.
there is a 6 pin connector, but it's not needed. it just links the drivers side mirror and controler switch to the fuse box and passenger's side mirror.
Re:electric mirrors
« Reply #23 on: 22 January 2004, 17:01 »
So does that mean on my diagram there should be only 1 6 pin connector on the drivers side?
« Last Edit: 22 January 2004, 17:01 by rubjonny »
Blue MK2
Re:electric mirrors
« Reply #24 on: 22 January 2004, 18:31 »
that means i have extra wires in the loom.
ohh well more for me ;D
cheers all
Blue MK2
Re:electric mirrors
« Reply #25 on: 22 January 2004, 19:20 »
just pulled the mirrors off their casing.
I cant see no heating element. all i see are two extra wires that look like they go to the heating element (whch is missing)
Ohh and both motors are identical. you have to remember which way they go otherwise you will press up and the motor will go left etc etc
Blue MK2
Re:electric mirrors
« Reply #26 on: 22 January 2004, 21:18 »
got it....
its missing the heater element that goes behind the mirror.
gotta buy new mirros with the heater element.
anyone got a rough price?
Offline modulater
Re:electric mirrors
« Reply #27 on: 22 January 2004, 21:55 »
Hopefully you've just both received the scan from my bentley manual, hope it helps.
Offline Ant
Re:electric mirrors
« Reply #28 on: 22 January 2004, 23:03 »
http://www.gpcvwaudi.com/
?30 for glass, but you'll have to check it's the heated sort (should be for that price)
Offline modulater
Re:electric mirrors
« Reply #29 on: 22 January 2004, 23:10 »
thats not too bad for what it is, I bet a main stealer would be expensive.
