Author Topic: electric mirrors  (Read 8643 times)
Offline Dizzie
  • Make friends with your fast
electric mirrors
« on: 20 January 2004, 19:33 »
got myself my passenger's side mirror, switch and loom today from the scrapper for ?15. I ripped out the dead mk2's dash so I could remove the loom in 1 peice and didn't have to cut it at all.
Is it possible to remove the motor part of the mech from the mirror and put it in a manual mirror as the ones on my car are colour coded and the electric ones are not?
I shall beginning wiring them up when the driver's side mirror shows up.
Blue MK2
Re:electric mirrors
« Reply #1 on: 20 January 2004, 20:10 »
Dizzy,
Ive picked up a set of electric mirrors with the full wiring loom, switch, etc etc for 70 notes. That a good deal? ???
Ill have a look for you
Offline Dizzie
Re:electric mirrors
« Reply #2 on: 20 January 2004, 20:20 »
the last set went for ?82 on ebay...
I just paid ?15 for mine ;D
although I'm missing 1 side that I also might have bought for ?15.
Offline Dizzie
Re:electric mirrors
« Reply #3 on: 20 January 2004, 20:24 »
OMG!
It's heated too!
the mirror just pulls out (carefully)
Blue MK2
Re:electric mirrors
« Reply #4 on: 20 January 2004, 20:24 »
yeah i picked the other set up off ebay
Blue MK2
Re:electric mirrors
« Reply #5 on: 20 January 2004, 20:26 »
are all the leccy mirrors heated? :o
i hope they are! ;D
Blue MK2
Re:electric mirrors
« Reply #6 on: 20 January 2004, 20:28 »
another thing..
where does the leccy mirror switch sit? do i have to cut holes to mount it ???
Offline Dizzie
Re:electric mirrors
« Reply #7 on: 20 January 2004, 20:31 »
the switch goes in the hole the adjuster leaves on the drivers side. a grommet goes in the other side...
aparently all proper mirrors are heated. I didn't know that until someone just said.
Offline Dizzie
Re:electric mirrors
« Reply #8 on: 21 January 2004, 00:16 »
right. the actual mirror pulls off. I've been told to be carefull when doing this...
then there's 4 screws to remove the motor part. the 4 wires just push into the back of the motors. this is lablled so you don't wire them up wrong when  you put them into the new shells.
There's another 4 screws that bolt the metal to the shell. you dont' need to undo these I don't think. Then I'm hoping it the same for the manual mirrors. it's a bit late to go working on the car outside now.
Re:electric mirrors
« Reply #9 on: 21 January 2004, 13:39 »
I've had a look on my Driver and the mirror shells LOOK identical, but without actually trying it I cant tell, I'll need to do the same as you on one of me mirrors cos one of the leccy ones I have has all the mounting screws broken off the mirror shell.  I got my set with most of the loom for ?35, it pays to look thru all the Golf classifieds :D
