Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 242621 times)
Offline Agreeable Slick
  • Unit
Re: ETKA part numbers - (just a trial at the mo)
« Reply #80 on: 13 December 2008, 13:08 »
191 853 717 A £29.60+ VAT.
« Reply #81 on: 09 February 2009, 08:52 »
028 919 081 D - oil pressure warning switch, 0.25bar - 7.65+VAT
N   903 059 01 - MK2 front bumper bolt, M10x73 - £2.05+VAT
« Reply #82 on: 19 February 2009, 15:35 »
Pre-90 arch trims:
191 853 717 A - left front - 55.09+VAT
191 853 718 A - right front - 55.09+VAT
191 853 817 B - left rear - 51.09+VAT
191 853 818 B - right rear - 51.09+VAT
« Reply #83 on: 22 April 2009, 08:15 »
357 412 329 - top mount, G60 - 30.69
1H0 953 513 C  01C - mk3 indicator stalk - 46.61
535 953 519 B  01C - mk3 wiper stalk w/ MFA - 49.31
Mounts I use 16v/G60 rear, 1.3 bonded rubber front & box. Febi ones from GSF/AVS have done me proud in the past, as you can see bit steep from VAG!
535 199 262 - rear engine mount, G60, 16v - 111.66
191 199 279 E - front mount, bonded rubber - 82.87
191 199 402 C - gearbox mount, bonded rubber - 49.8
191 955 531 - internittant wiper relay - 23.66
3B0 955 531 - variable intermitant wiper relay - 26.61
all prices not enc vat :)
« Reply #84 on: 05 June 2009, 10:51 »
there is an early mk1 part:
063 133 555 - 1.81+VAT
Cant say if it will work but a set of 4 wont break the bank.
063 133 555 A - is early MK2 and disconned
Just a thought, have you found out the engine code of it yet?
« Reply #85 on: 08 June 2009, 14:31 »
191711595A - short selector rod, MK2 1.6-1.8 5 speed - 1.7€
« Reply #86 on: 22 June 2009, 09:04 »
7 - 191 512 113 - upper spring disc - 11.10+VAT
8 - 191 512 117 - spacer slieve - 4.16+VAT
9 - 191 512 119 - ring - 1.49+VAT
10 - 191 512 131 B - bump stop - 14.92+VAT
12 - 1H0 512 149 - rubbber spring mount - 2.58+VAT
13 - 191 512 333 - lower rubber top mount - 4.16+VAT
14 - 191 512 335 - upper rubber top mount - 4.16+VAT
15 - N   103 286 02 - hex nut, M10x1 - 0.26+VAT
16 - 191 512 339 - pressure washer - 1.49+VAT
17 - 191 512 340 - support washer - 1.49+VAT
18 - 191 512 337 - concave washer - 0.79+VAT
21 - 8D0 512 097 - snap ring  - 0.53+VAT
« Reply #87 on: 15 July 2009, 10:44 »
Push fit temp sensor rubber seal, i.e. 2 pin ECU and temp on MK2, 4 pin on MK3 etc
N   903 168 02 - 0.94+VAT
« Reply #88 on: 24 July 2009, 15:47 »
028 103 500 - MK2 8v pcv valve (flying saucer) rubber bung - 2.73+VAT
« Reply #89 on: 03 August 2009, 08:38 »
MK2 tailgate numberplate fixing inserts:
321 813 998 A - >> 1G-N-004 000 (8x8mm) - 0.47+VAT
357 827 998 A - F 1G-N-004 001>> (10x8mm) - 0.47+VAT
the above is a chassis number break, which occured around august 91 :)
edit: but you cant know for sure what year your tailgate is, so best to measure the hole (and check there still is one  :grin:)
« Last Edit: 03 August 2009, 08:40 by rubjonny »
