Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 242356 times)
Offline Uruk Hai
Re: ETKA part numbers - (just a trial at the mo)
« Reply #70 on: 23 April 2008, 16:31 »
If you change your sump gasket and replace it with a rubber (thicker) one these are the bolts you'll need
N904 234 02   M6 x 17mm  .67p inc VAT
« Reply #71 on: 03 May 2008, 12:06 »
Lower shield from back of gearbox on big block engines:
068 103 648 D - cover panel - £14.24+VAT
F             >> 1G-LW234 003
F             >> 1G-LB037 030
068 103 648 K - cover panel - £13.38+VAT
F 1G-LW234 004>>
F 1G-LB037 031>>
The 2 codes underneath reference your VIN number, top part number is 'up to' bottom is 'from' :)
« Last Edit: 03 May 2008, 12:26 by rubjonny »
« Reply #72 on: 11 August 2008, 16:50 »
1H0 121 321 C - 90 onwards header tank cap - 5.99+VAT
191 845 121 - MK2 windscreen seal - 25.18+VAT
« Reply #73 on: 20 September 2008, 11:31 »
171 121 407 F - pre-90 kidney shaped header tank - 24.74+VAT
1H0 121 407 A - post-90 round header tank - 28.63+VAT
« Reply #74 on: 24 September 2008, 09:16 »
can get em from GSF:
18004 Feed pipe 1.6-1.8 8v
18004B Feed pipe 16v
18005 Return pipe 1.6-1.8 all
« Reply #75 on: 10 October 2008, 10:16 »
1H0 711 183 - mk3 weighted shift rod - 11.29+VAT
« Reply #76 on: 22 October 2008, 10:34 »
1H6 955 651 - washer pump - 27.86
Looking at that part number it might be a MK3 item, which has a different plug on it.  ETOS notes you also need:
357 972 752 - flat contact housing - 3.95
357 972 741 A - single wiring seal - 0.39 x2
which seems to support that assumption.  GSF will probably be able to sort you out with one, see if they have ones with the non-return valve in!  You can tell it has by looking at the output pipes, the nr valve is a big round blobby bit on there...
« Reply #77 on: 30 November 2008, 10:36 »
1. think its this, pic isnt that clear:
191 611 797 B - retainer - 27p+VAT
2. the big metal clip things have been deleted and replaced with:
N   011 666 15 - washer - 16p+VAT
N   038 601 1 - nut, thread cutting - 0.10p+VAT
« Reply #78 on: 05 December 2008, 14:11 »
193 919 059 B
etos suggests it is deleted, etka gives price to be about £50+VAT :)
Offline Agreeable Slick
  • Unit
« Reply #79 on: 11 December 2008, 21:17 »
N 013 964 9 - Oval Panel screw - £0.12p x12.
191 867 149 - Loudspeaker Grill x2
191 867 139 - Detent Spring x2
191 867 133 - Storage box  x2
