Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 242395 times)
Re: ETKA part numbers - (just a trial at the mo)
« Reply #60 on: 27 May 2007, 11:54 »
191 971 926 B - rear panel grommet (33.5mm) - £3.62 - (post 90)
191 971 908 B - rear panel grommet (19.5mm) - £0.32 - (pre 90)
321 813 998 A - tailgate insert nut 8x8mm - £0.43
357 827 998 A - tailgate insert nut 10x8mm - £0.43
191 867 775 A  01C - parcel shelf hook - £0.26
« Reply #61 on: 31 July 2007, 23:11 »
sunroof seal is on page 3, bolt:
N 903 079 01 - hex head bolt, MK2 front door hinge - M10x15 - 92p
« Reply #62 on: 01 August 2007, 08:31 »
1H0 853 586 - rubber plug for rubbing strip clips - 34p
191 853 585 A - plastic clip for rubbing strips - 23p
« Reply #63 on: 30 August 2007, 12:30 »
MK2 Front engine mount bracket/starter motor bolts:
N   044 760 1 - allen key head bolt, M10x135 - £1.56+VAT x2
N   102 862 03 - hex head bolt, AM10x60-SW16 - £0.62+VAT
« Reply #64 on: 09 September 2007, 12:24 »
Theres 2 listed depending on the year:
Early:
N   019 700 2 - bolt, M8x30 - 1.06+VAT
Late:
027 903 555 - bolt - 9.24+VAT
I assume the late one is expensive becasue it comes with the toothed wheel thingy?
« Reply #65 on: 31 December 2007, 11:32 »
I think I know what you mean, number 16? Heres a part # breakdown:
14 - £0.24+VAT x2
15 - £0,24+VAT x2
16 - £2.17+VAT x2
Or if you actually want to take the cup off and replace the seal behind it, you need the 'repair kit' #27 which is £8.70+VAT.
I've never seen a driveshaft seal actually fitted to a car I've worked on, but they do exist in ETKA :)
« Reply #66 on: 03 March 2008, 08:45 »
got 2x possibilities:
027 133 689 R - 8x3.7mm - 0.95+VAT (apparently theres 3 of these)
051 133 689 A - 8x8.5mm 0.82+VAT
« Reply #67 on: 17 March 2008, 12:14 »
026 198 025 C - 8v rubber rocker cover gasket - £10.98+VAT
026 198 025 C - 8v rubber rocker cover gasket kit w/ studs - £12.25+VAT
« Reply #68 on: 09 April 2008, 08:18 »
personally I think you're crazy, but heres the list:
Front:
8 - 191 412 341 - spring disc - £12.26+VAT x2
8 - 357 412 341 - spring disc, G60 - £12.26+VAT x2
11 - 171 412 369 - washer - £0.24+VAT x2
20 - http://www.vwspares.co.uk/product_info.php?products_id=501 (non G60) x2
20 - http://www.vwspares.co.uk/product_info.php?products_id=598 (G60) x2
Rear:
5 - 3A0 512 103 - lower spring disc (usually part of strut) - £10.10+VAT x2
6 - 321 512 109 - base (usually part of strut) - £1.31+VAT x2
8 - 191 512 117 - spacer slieve - £3.74+VAT x2
9 - 191 512 119 - ring - £1.31+VAT x2
15 - N   103 286 02 - hex nut - £0.23+VAT x6
16 - 191 512 339 - pressure washer - £1.31+VAT x2
17 - 191 512 340 - support washer - £1.31+VAT x2
18 - 191 512 337 - concave washer - £0.73+VAT x2
19 - 191 513 269 - protective cap (usually part of strut) - 0.24+VAT x2
20 - 191 513 425 - boot - 3.10+VAT x2
« Reply #69 on: 19 April 2008, 10:37 »
191 945 111 F - left - deleted
192 945 112 B - right - 34.50
