Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 242397 times)
Re: ETKA part numbers - (just a trial at the mo)
« Reply #40 on: 26 October 2006, 15:35 »
3 light switches listed, no idea which is which, so confirm the # off your old one before u buy:
191 941 531 K - light switch - £16.37
191 941 531 L - light switch - £16.37
191 941 531 M - light switch - £16.37
191 941 535 B - fog light switch - £11.94
191 953 235 - hazard switch (pre 90- spec) - £9.67
191 959 621 B - switch for heated rear window - £9.67
191 959 855 01C - electric window switch - £15.61
191 919 550 - holder for rear door electric switch - £2.32
191 959 561 - 4 door electric window lockout switch - £11.94
321 959 565 - switch for electric mirrors - £17.68
357 953 519 01C - post-90 wiper stalk - £42.16
535 953 519 A 01C - post-90 wiper stalk with MFA - £44.73
357 953 513 F 01C - post-90 indicator switch - £38.03
535 953 513 A 01C - post-90 indicator switch with cruise control - £66.79
191 953 519 01C- pre-90 wiper stalk - £26.75
191 953 519 A 01C - pre-90 wiper stalk with MFA - £45.74
191 953 513 B 01C - pre-90 indicator switch - £17.68
191 953 513 C 01C - pre-90 indicator switch with cruise control - £44.73
Unlikly that you want these, but for completness:
533 959 855 A - switch for electric seats - £13.50
191 963 563 - switch for driver & passenger seat heating - £54.50
191 963 563 A - switch for driver side only seat heating - £34.45
191 941 333 - switch for headlight range control - £40.15
Prices do not include VAT :)
Offline Uku
« Reply #41 on: 26 October 2006, 16:35 »
a few more , just picked em up today for my golf mkII 8v
V192 823 509 hood lock (bit with lil spring inc)  10.54 ex vat.
V191  711 173 B Relay Shaft (this is that lampost shaped bit with the rubber ball that hangs off , often find it disintegrates and just leaves a star edged plastic bit , gives massive sloppy movement on gearstick forward and backwards)  costs 30.46 ex vat.
Offline Ben Lessani
« Reply #42 on: 28 October 2006, 00:11 »
P V192 819 415C N/STK Deflector  -  the plastic scuttle under the bonnet. mention trade discount to any dealer and get it for £10 + vat
« Reply #43 on: 05 November 2006, 22:16 »
That is the correct part # for a MK2 16v yep :)
027 121 133 E - plastic coolant flange from front of cylinder head, KR/9a - £7.85+VAT
« Last Edit: 31 July 2007, 23:06 by rubjonny »
Offline Uruk Hai
« Reply #44 on: 06 November 2006, 16:23 »
037 121 133 C - Flange £8.70 + VAT
Its the plastic piece that goes on the cylinder head and both temp senders go into it and 3 hoses.
(its for the 1800 Digifant 8V)
026 121 144 E - Flange £5.19 + VAT (Geniune VW part)
The one that goes onto the side of the head with one hose connecting
(also 8V Digi)
« Last Edit: 04 February 2008, 17:18 by Uruk Hai »
« Reply #45 on: 09 November 2006, 15:51 »
191 853 661 - Golf Grill Trim - £18.72 + VAT
165 853 661 - Jetta Grill Trim - £18.72 + VAT
« Reply #46 on: 10 November 2006, 22:24 »
048 109 129 - £11.15+VAT
Thats a generic pic, its actually a 1.8 lump there as it shows the back end of the cover seperate, whereas on the 2e the piece is built into the rocker cover.
« Reply #47 on: 21 November 2006, 08:17 »
From VW:
191 711 173 B - relay shaft - £30.46
From GSF:
71707C - GEAR LINKAGE SHIFT FINGER - 15.50
And no, it doesn't come with the kit :)
« Reply #48 on: 22 November 2006, 23:10 »
191 906 090 - main pump
no colour listed though!  Don't remember mine being anything but silver when I serviced it...
« Reply #49 on: 29 November 2006, 21:40 »
037 905 237 AX - 2e distributor - £87.35+VAT
« Last Edit: 31 July 2007, 23:04 by rubjonny »
