Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 242381 times)
Offline shikta000
Re: ETKA part numbers - (just a trial at the mo)
« Reply #30 on: 15 August 2006, 13:12 »
this is the temp. sender for pre '88 digifant. ( this was replaced by the 'blue' temp . sender in later models;
035 919 369 m           around £30.
« Reply #31 on: 24 August 2006, 13:41 »
All early GTI seats have single piece seat base foams, which means any pre-90 GTI passenger seat will do ;)
Only the post 90 spec MK2 seats had 3 piece ones :)
191 881 375 D - £58.53
Listed for:
84-89 Golf/Jetta
84-93 Cabrio
82-88 Passat
82-94 Polo
Best you start looking for a passenger seat base ;)
« Reply #32 on: 01 September 2006, 08:31 »
06B 103 485 B - MK2 16v oil cap - deleted :(
06B 103 485 C - MK3 16v oil cap - £4.10+VAT
Only difference is that the MK3 cap will have a warning about not overfilling the oil because it will damage the cat
« Reply #33 on: 05 September 2006, 08:56 »
192 721 335 H - clutch cable self adjusting - £28+vat
192 721 335 G - clutch cable - £17+vat
Don't bother with the self-adjusting cable, the manual ones are better and will last longer normally.
« Reply #34 on: 15 September 2006, 11:53 »
020 945 415 A - switch for reversing light - 2 pin - £7.51+VAT
« Reply #35 on: 15 September 2006, 13:13 »
It will fit on ok, it isn't actually listed for the Golf G60, but it is for the Corrado. The correct centre for the Golf G60 wheel is:
357 601 149 D  V7L - £9.69
Which is flat & silver :)
« Reply #36 on: 25 September 2006, 23:22 »
heater element under the inlet manifold for golf 1.3
026 129 893 - £67.08+VAT
« Last Edit: 10 November 2006, 14:48 by Pedro Muchacho... »
« Reply #37 on: 27 September 2006, 21:01 »
ECU temp sender is listed on the 1st page ;)
192 721 555 A - throttle cable 8v & 16v - £15.16+VAT
« Reply #38 on: 06 October 2006, 14:47 »
871 601 171 - wheel cap - £3.87+VAT
055 121 121 F - connecting socket - £5.58+VAT
Offline snake16valve
« Reply #39 on: 11 October 2006, 17:50 »
Here are a couple more...
035 133 557A.  Set of 4 injector seals.
020 141 073A. Green gearbox end cap.
« Last Edit: 21 October 2006, 20:53 by snake16valve »
