Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 242345 times)
Re: ETKA part numbers - (just a trial at the mo)
« Reply #90 on: 04 August 2009, 10:17 »
oem MK2 ones discontinued, but SEAT part fits and is cheaper:
357 615 311 A - 280mm brake splash shield - 5.65+VAT
« Reply #91 on: 14 September 2009, 10:26 »
191 947 561 - MK2 golf boot light switch - deleted
might be worth a call anyway, I assume the part number has been replaced rather than dropped completly.
« Reply #92 on: 15 September 2009, 14:47 »
the double stud is not avail seperately :(
nut is 171 857 026 A, but discontinued. its only an M5 nut with a built in shoulder though, so easy to get. VAG might be able to quote a replacement part number if you give them the old number though.
If you mean the bolts with a bit of threadlock on that are 13mm and go into the slider pins, its 321 615 141 and that works for front & rear. again its deleted though, but VAG should be able to quote you a replacement number.  If you go for 443 698 470, thats the part number for 2 of rubber slider pin boots, this will include special slider pin grease and also should come with 2 new bolts also. Yet again this number seems to be deleted, but VAG should be able to give you the replacemnt part number for it.
« Reply #93 on: 16 November 2009, 16:05 »
035 919 369 M - pre 88 digifant white temp sensor - 33.56+VAT
« Reply #94 on: 11 January 2010, 13:53 »
191 953 519 A  01C - 87-89 MFA stalk - discontinued :(
VeeDubGTI16v
« Reply #95 on: 14 February 2010, 10:49 »
dont worry, found the number!
mk3 spring plates to fit mk3 mounts and mk2 springs
1h0 412 341
Re: ETKA part numbers - Post queries here - Often trimmed down
« Reply #96 on: 16 February 2010, 10:22 »
171 721 232 - clutch pedal stop - deleted :(
you can use a bolt and 2 nuts instead :)
« Reply #97 on: 20 April 2010, 14:03 »
probably a bit late now, but part numbers are:
1H0 201 653 F - strap, left - 14.43+VAT
1H0 201 654 C - strap, right - 14.43+VAT x2
same part numbers as MK3, so should be plentiful in scrappy
357 877 209 A - B3 Passat glass sunroof seal - 41.99+VAT
Offline twistedblack69
  • Proud mk2 user and abuser
« Reply #99 on: 22 June 2010, 10:03 »
Looking for clarification on this part 192 612 105 C does anyone know if it's a 20mm master cylinder or 22mm
