Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 242347 times)
Re: ETKA part numbers - Post queries here - Often trimmed down
« Reply #100 on: 22 June 2010, 10:08 »
thats a brake servo,  not a master cylinder. the master cylinder will have 20 or 22mm stamped on it somewhere
« Reply #101 on: 26 June 2010, 19:31 »
they're m6 nuts now:
N   011 183 12 - m6 nut - 0.23+VAT
« Reply #102 on: 06 July 2010, 08:43 »
just give em this part number:
049 919 501    - Temp Sender - 1 Pin Black
Offline drapergti
« Reply #103 on: 08 July 2010, 20:08 »
Hi
Found this in the garage, and must have left it off the car at some point!
191.819.713
thin strip of black plastic about 2 inches long.
Could it be the reason my fan does not blow through the front air vents  :rolleyes:
Thanks
« Reply #104 on: 12 July 2010, 14:34 »
1. cant buy seperately, but it from simply bearings, you need size 12x19x5. I got the one with the dust seal lip:
http://simplybearings.co.uk/
2. 020 311 113 b - input shaft seal, 2Y gearbox - 5.62+VAT
3. 049 919 501 - temperature sensor 1 pin black - 27.45+VAT x3
« Reply #105 on: 19 July 2010, 16:32 »
think what you want is:
1J0 898 079 - 1 set: securing parts for armrest - 28.43+VAT
Offline tony_ack
« Reply #106 on: 16 August 2010, 16:22 »
Could you get part numbers and prices/availability for:
2Y gearbox pushrod seal
16v backbox (don't worry, I'm sat down..)
Roof gutter trim clips
Front big bumper plastic 'fin trims' (the three black plastic bits that go over the joins between the upper and lower sections of the painted bit of the bumper)
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
« Reply #107 on: 17 August 2010, 09:16 »
020 311 108 A - pushrod seal - 14.48+VAT
big bumper 16v back box was dropped in 2009 without replacement :(
191 853 733 A - gutter clip - 0.5+VAT
front bumper fins dropped in 2010 without replacement :(
Offline Neo Badness
  • Feet are for pedals
« Reply #108 on: 21 August 2010, 23:17 »
answered my own question, well almost. :smiley:
PAS gaitor 192 419 523F
Non PAS gaitor 192 419 523e (Obsolete)
« Reply #109 on: 01 September 2010, 09:17 »
191 953 515 A  LN8 - 90spec upper trim - 7.57+VAT
191 953 516 A  LN8 - 90spec lower trim - 9.93+VAT
191 953 515 C  LN8 - pre-90 upper trim - 7.57+VAT
pre-90 lower trim NLA
