Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 242340 times)
Re: ETKA part numbers - Post queries here - Often trimmed down
« Reply #120 on: 22 January 2011, 17:22 »
037 133 992 C - abf fuel rail elbow - 10.25+VAT
N   905 581 01 - abf fuel rail o'ing - 3.75+VAT (2 per rail outlet/inlet)
« Reply #121 on: 24 January 2011, 14:54 »
037 133 990 P - feed hose - 20.82+VAT
037 133 988 L - return hose - 26.87+VAT
« Reply #122 on: 14 February 2011, 10:08 »
023 129 101 - pressure regulating valve - 45.31+VAT
028 103 500 - pressure regulating valve seal - 2.98+VAT
Offline emery1990
« Reply #123 on: 12 March 2011, 18:23 »
Part number needed for hall sender please  :smiley:
« Reply #124 on: 12 March 2011, 19:05 »
for your 16v I assume? ;)
052 998 065
its deleted, but you can get it from VW classic parts. not cheap though!
http://www.volkswagen-classic-parts.de/e_content.pl?src=e_cp_index
Offline emery1990
« Reply #125 on: 13 March 2011, 14:53 »
yep  :grin:
It has 2 hall senders, ones $48 the others $138!
Best actually check if it is 100% broke with those prices!
Offline Neo Badness
  • Feet are for pedals
« Reply #126 on: 13 March 2011, 21:00 »
I need to get the part number for the bits that hold the front ARB bushes in place on mk2 golf, small u-brackets, plus the 13mm bolts that hold them in too please.
I also need to get the part number of the 19mm bolt that hold the wishbone on.
Thanks in advance :smiley:
« Reply #127 on: 14 March 2011, 09:37 »
191 411 334 - MK2 inner ARB bracket - 1.65+VAT
N   019 538 2 - MK2 inner ARB bracket bolt, M8x18 - 0.40+VAT
N   100 874 03 - mk2 rear wishbone bolt, M12x1.5x74 - 1.89+VAT
N   904 840 04 - mk2 front wishbone bolt, M12x1.5x82 - 1.39+VAT
Offline Neo Badness
« Reply #128 on: 14 March 2011, 12:13 »
Thanks very much RJ :smiley:
Offline redders
  • 88 8V GTI, 3dr helios blue
« Reply #129 on: 02 April 2011, 20:02 »
part no. for front wings golf mk 2
