Author Topic: Anyone local got vagcom/obdeleven (reading)  (Read 30130 times)
Offline Jeni_R_
Re: Anyone local got vagcom/obdeleven (reading)
« Reply #50 on: 27 September 2017, 20:09 »
Had a few instances where OBD11 and Carista can't do quite as much as VCDS. Recently on an A3 (MY17) where it failed to turn on audible locking confirmation. With some stuff they are a little behind in implementing (to do with them needing to implement ASAM data).
Though I'd say it's a feasible and cheaper alternative but would recommend to write down all changes as it doesn't keep a log (like VCDS or VCP do on the PC) so you can revert back to original if you have to or want to for any reason.
You may be right, but in the context of a mk7 Golf OBDeleven did activate acoustic locking for me. Also, there is a history of all changes made which I have made use of. And it's only £40.
Obdeleven is only £40 ?
Offline Jeni_R_
« Reply #51 on: 27 September 2017, 20:24 »
Obdeleven is not as feature rich as VCDS, particularly on the diagnostics side, no question about that, but for the money it covers the majority of adaptations and a good level of diagnostics. Well worth the money.
I have done way more on my Mk7 with OBDeleven pro than I ever did with my VCDS in my CC's
VCDS is great if your doing it as a weekly thing or have different VAG cars but if you only have a Mk7 then I'd pick the OBDeleven every time, and for the the extra price if the pro it's a no brainer to get that.
Long choosing may look a bit daunting at first but it is easy as hell if you follow the many guides  on here and other forums and make sure you do a backup first..
On that link theres obdeleven  £35 and then a pro pack do i need both ?
Offline I wanted a GTi
« Reply #52 on: 27 September 2017, 21:11 »
Go to Booth11's link and scroll towards the bottom and buy both the OBDeleven £35.10 and the pro key £21.93 and your done. The pro key is just a code written on the little bag that it comes in.
Offline Jeni_R_
« Reply #53 on: 27 September 2017, 21:42 »
Has anyone got that key or is it unique to each purchased ? Like a win10 activation key can b used more than once is it the same with this ?
« Reply #54 on: 27 September 2017, 21:54 »
No the pro key is a onetime thing, it is for the OBDeleven that you get. You download the app from the google app store and register your details to log into it, you can use your facebokk or twitter logins if you want but you don't have to. When you've logged into it you can then enter your pro code.
Offline wantmygti
« Reply #55 on: 27 September 2017, 21:59 »
My bad, it's €40 plus the pro key. You can buy this code at a later date if not sure.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline Jeni_R_
« Reply #56 on: 27 September 2017, 22:07 »
So do u need the pro code to alter sound aktor and light settings or can i do that with just the ebdeleven itself ?
« Reply #57 on: 27 September 2017, 23:08 »
Yes, but even if you could do it without the pro code you would have to pay to get the credits to do it. For the extra money it costs for the pro I wouldn't dream of not getting the pro key.
Jesus I sound like a promoter for them :grin:
Offline Jeni_R_
« Reply #58 on: 28 September 2017, 07:06 »
Bet u are one   :laugh:
I shall go have a good read up today and if i think i can do the stuff which i shud b as have a good programming brain then will order today dont think anyone local to me has one so ...
« Reply #59 on: 28 September 2017, 08:18 »
Once you get your head around it all(did I mention long coding is mostly in german) but the guides are so easy to follow. Have a look here http://obdeleven.proboards.com/board/81/mk7
Don there is very helpfull is very easy to follow guides.
