Author Topic: Anyone local got vagcom/obdeleven (reading)  (Read 30153 times)
Offline Booth11
Re: Anyone local got vagcom/obdeleven (reading)
« Reply #40 on: 27 September 2017, 16:07 »
I will be cheeky and ask too ..............does anybody have this up in Scotland ? i believe i need this to adjust the sound aktor ? :undecided:
Jeni, I'm sure you will find someone close by but if not, if you ever come down to Kent, give me a shout as I have obdeleven.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline itavaltalainen
« Reply #41 on: 27 September 2017, 16:14 »
Sure, we're back on topic.
OP just has gone quiet :D
Offline Jeni_R_
« Reply #42 on: 27 September 2017, 16:16 »
Hope so  so many things you need it for and dont know where to get one from or what one to get as so many opinions  :rolleyes:
« Reply #43 on: 27 September 2017, 16:48 »
Have you had a look at the VCDS user map?
Unfortunately not 100% up to date all the time but am sure there's a few of us up in Scotland too.
http://www.vcdsusers.uk
Offline Booth11
« Reply #44 on: 27 September 2017, 16:51 »
If you can't find someone or want to do it yourself - go for Obdeleven as it's considerably cheaper than VCDS and user friendly.
Buy direct from here https://obdeleven.com/en/
The Pro version enables you to do long coding as well as use apps to make changes.  It only runs on Android (I bought a cheapy Android tablet as I'm apple user).  Cheeky to direct you elsehwere but lots of info on the R forum and lots of coding on there too.
http://www.vwroc.com/forums/forum/84-obdeleven/
« Last Edit: 27 September 2017, 16:55 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline wantmygti
« Reply #45 on: 27 September 2017, 17:00 »
I'd second all of the above - quite easy to pick up from scratch.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
« Reply #46 on: 27 September 2017, 17:24 »
Had a few instances where OBD11 and Carista can't do quite as much as VCDS. Recently on an A3 (MY17) where it failed to turn on audible locking confirmation. With some stuff they are a little behind in implementing (to do with them needing to implement ASAM data).
Though I'd say it's a feasible and cheaper alternative but would recommend to write down all changes as it doesn't keep a log (like VCDS or VCP do on the PC) so you can revert back to original if you have to or want to for any reason.
Offline wantmygti
« Reply #47 on: 27 September 2017, 17:46 »
You may be right, but in the context of a mk7 Golf OBDeleven did activate acoustic locking for me. Also, there is a history of all changes made which I have made use of. And it's only £40.
Offline Booth11
« Reply #48 on: 27 September 2017, 18:19 »
Obdeleven is not as feature rich as VCDS, particularly on the diagnostics side, no question about that, but for the money it covers the majority of adaptations and a good level of diagnostics. Well worth the money.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline I wanted a GTi
« Reply #49 on: 27 September 2017, 19:49 »
I have done way more on my Mk7 with OBDeleven pro than I ever did with my VCDS in my CC's
VCDS is great if your doing it as a weekly thing or have different VAG cars but if you only have a Mk7 then I'd pick the OBDeleven every time, and for the the extra price if the pro it's a no brainer to get that.
Long choosing may look a bit daunting at first but it is easy as hell if you follow the many guides  on here and other forums and make sure you do a backup first..
