Author Topic: Anyone local got vagcom/obdeleven (reading)  (Read 30129 times)
Offline canalmike
Re: Anyone local got vagcom/obdeleven (reading)
« Reply #70 on: 27 June 2018, 23:59 »
Thanks Don but
[/quote]
Anyway, it's an easy thing to check. Just log-into the Structure Borne Sound control module, then navigate to the only adaptation channel in this module and check if it's value is set to 0
Don
[/quote]how....?
Offline Vwjap
« Reply #71 on: 28 June 2018, 07:42 »
Same way you turned it down/off, just check the setting you changed is still the same and not turned back up
Offline itavaltalainen
« Reply #72 on: 28 June 2018, 20:36 »
I've coded it out, would be weird for it to reset itself!
This is the coding you need to do:
Address A9   5G0 907 159    channel IDE04472-Volume of structure-borne noise actuator   adapted from   100.0 %   to   0 %   Monday   2   April   2018   14:07:32:58731
I won't likely get to MK any time soon (or at all anymore) as I'm soon moving to Germany.
Offline canalmike
« Reply #73 on: 29 June 2018, 16:14 »
Thanks.
Hopefully I'll find someone else around MK, or invest in a OBD11 which might save future hassle.
Offline kane1210
« Reply #74 on: 29 June 2018, 20:02 »
Just brought OBD11! I'm located in Bracknell if anyone has any tips or wants to give a run through with the device if your local to me obviously.
Offline canalmike
« Reply #75 on: 29 October 2018, 11:27 »
Finally bought an OBD and have made various adjustments. A few via free credits and some with the Pro key via the 'adaptions' options.
One that's stumped me, and instructions on the Pro board are inadequate: to alter the 'puddle lights' (ambiant lighting) I found:
 The following coding applies:
    Select STG 52 (Beifahr Türelektr..)
    STG long coding -> function 07
    byte 01
    Disable Bit 5
    Select STG 42 (driver Türelektr.)
    byte 01
    Disable Bit 5
but no helpful explanations anwhere of how to do this. Anyong give a step-by-step guide?
