Author Topic: When life gives you lemons........? Help  (Read 87293 times)
Offline Screech16v
  • MK3 20vt AGU
Re: When life gives you lemons........? Help
« Reply #60 on: 24 March 2014, 23:08 »
Sounds like a collapsed/blocked breather pipe ,crankcase pressure that would normally go into the intake system cant, so forcing oil past the valve stem seals,just my 2p
« Reply #61 on: 24 March 2014, 23:40 »
Nino is right, I would not be driving it at all, your making any damage worse.
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« Reply #62 on: 24 March 2014, 23:42 »
I took niño advise! It got on a low loader and is now in Brighton find out tomorrow
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline Nino
  • Insta - F6UGA
« Reply #63 on: 25 March 2014, 06:37 »
Good lad. Keep us posted.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline Dalo Harkin
« Reply #64 on: 25 March 2014, 08:25 »
You need to take the TIP off at the turbo, check for play both side to side and up and down.
my turbo has recently gone, it took me 3 hours to take it off, costing me £250 for a full refurb (pound notes  :whistle: ) and then ill fit it again at weekend...... worth just taking the TIP off to check before you get slammed for nearly 4 figures!
Offline XMC1980
« Reply #65 on: 25 March 2014, 10:26 »
okay....... here we are so far
the turbo has more play than whores fanny!!!
anyone know where I can get one from?
Mk4 1.8T 218ps AUQ
Offline XMC1980
« Reply #66 on: 25 March 2014, 11:36 »
damage report
turbo £320
thermostat 15.80
temp sensor £10.02
timing kit £70.80
water pump £28.80
head set £50.80
head bolt £28.77
oil filter £5.80
air filter £7.20
plugs £27.20
head test £35.00
valve seals £15.00
disks and pads £103.00
breather pipes £90.00
parts £808.37
vat    £161.64
labour £500.00
total £1450!!!!
HAPPY FOOKING TUESDAY
Mk4 1.8T 218ps AUQ
Offline Dalo Harkin
« Reply #67 on: 25 March 2014, 12:39 »
Whos quoted you all that? if the turbo is knackered replace that and go from there (yes there may be an underlining issue with a breather pipe or something) most of which you will do when you take the turbo out anyway as you'll lose all the oil and coolant anyway making it easier to investigate breathers and pipes as most will be coming off
Do the work yourself (if you were closer I would help) and get the turbo refurbished - job done
Is it a K03s?
« Last Edit: 25 March 2014, 12:47 by Dalo Harkin »
« Reply #68 on: 25 March 2014, 12:58 »
Break it for spare, cut your losses and move on might be the best option.
Offline XMC1980
« Reply #69 on: 25 March 2014, 13:16 »
Its a bit late now as the car is almost apart, new discs and pads are on and the turbo is being collected today, refurbed and fitting kit as quoted above, as for the rest ill be honest I have no faith and don't want to be in this situation anytime soon so im just going to do it.
compressions were at 150 apart from 1 cylinder at 130 but the problem is if I drive away and the valve stem seals are gone then all this will tip me over the edge.
he is a family friend and he is extremely good, so I trust him, at least it will be all done properly
I know that there were other options but no one lived closer and and we all have jobs I assume....
thanks for all your help guys I really appreciate it.
ill update as I go along and hopefully be done for thursday
Mk4 1.8T 218ps AUQ
