Author Topic: When life gives you lemons........? Help  (Read 87177 times)
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« on: 20 March 2014, 20:00 »
Bought my third golf today and I'm so worried I made a mistake!
The car is absolutely solid bodywork wise apart from a few expected age related marks and the front anniversary valance needs painting "properly"
Interior is excellent.... Everything works
Brakes need new pads on the front, suspension is good just a rear top mount if your fussy like me
Wheels are all good and rear tyres are near new
BAD POINTS....
I noticed 5 miles up the road that there was quite a lot of white smoke behind me :( whilst I was on idle is when it's bad, I checked the oil over a 90 mile trip home on three occasions just to be sure. My girlfriend was driving behind me and said once I was driving she didn't see any, only at first, but when we refuelled I started the car and the smoke was there again! It's quite bad when it happens and smells both sweet and oily "more sweet" and there is a sporadic "oil sensor workshop" that flashes up when starting, 4/5 times.
The oil looks really new and the level was perfect there and back and the turbo was working perfect, I know it could be bad news but I thought maybe it is fixable so please give me some good news
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline XMC1980
Mk4 1.8T 218ps AUQ
Offline Nino
  • Insta - F6UGA
Re: When life gives you lemons........? Help
« Reply #2 on: 20 March 2014, 20:35 »
White smoke is not a good sign, Have you tired un-doing the oil cap? is there any mayo like stuff on the cap?
Could be a number of things, Head gasket, bad fuel, really bad boost leak.
shame your not closer to me Id scan it for you.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline XMC1980
« Reply #3 on: 20 March 2014, 20:40 »
No signs of bad oil or mayo but the oil was really fresh....
I am heartbroken as the missus will KILL me
Mk4 1.8T 218ps AUQ
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 20 March 2014, 20:41 »
Oh damn. Take it back to the seller. Did you give him cash? Did you sign any paper to say sold as seen? I forgot to say always take someone down with you who knows more about cars than yourself. I hope it aint bad and just a boost leak from a pipe.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 20 March 2014, 20:42 »
Tell her to feck off :grin:
or just dont tell her?
*****MK4 GTI T*****
Offline Nino
  • Insta - F6UGA
« Reply #6 on: 20 March 2014, 20:54 »
Have you checked the antifreeze? has it got oil in there?
The sweet smell would suggest that the antifreeze is leaking into the combustion chamber.
Have you double checked for sure what the colour of the smoke is?
Blue = oil in combustion chamber
White = Water in combustion chamber
Ether way it will ether be head gasket, worn block or broken piston rings.
Personally Id take it back unless you can buget £400-700
Offline mike1990
« Reply #7 on: 20 March 2014, 20:56 »
Yes, sounds like head gasket, block or the piston rings. Get it compression tested and squirt a little oil in the cylinder that's low on compression and compression test again. If the compression goes up, it's the rings.
Offline daz veedub
  • Operation 1.8t bolf
« Reply #8 on: 20 March 2014, 21:24 »
Gutted mate looks sweet aswell  :sad: worth contacting the seller
Offline XMC1980
« Reply #9 on: 20 March 2014, 21:45 »
Okay the seller has given me £150 back, he says it was running fine? I guess now I need someone sensible do look at it for me, the smoke has died right down now as I took it for a spin? I don't mind travelling to anyone who fancies looking at it and taking the job on?
Mk4 1.8T 218ps AUQ
