Author Topic: When life gives you lemons........? Help  (Read 87510 times)
Offline Nino
  • Insta - F6UGA
Re: When life gives you lemons........? Help
« Reply #50 on: 23 March 2014, 23:13 »
Yes slick 50 is the stuff you want, stay away from oil flush treatments they have a tendancy to block the oil pickup pipe
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« Reply #51 on: 24 March 2014, 12:10 »
I am absolutely raging now, the car has been fine for the last 3 days and this morning loads of blue smoke that smells of oil :( I don't know who to call where to go .... Can't help but think I'm fooked now
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline Dalo Harkin
« Reply #52 on: 24 March 2014, 13:02 »
You need to start with some investigations - take the TIP off at the turbo side and check for any play in the spindle, wiggle it side to side and then see if there is any movement up and down.. this will check for turbo damage.
If the turbo is ok then you are wanting to be looking at the block next.
Did you get a compression test done?
Offline XMC1980
« Reply #53 on: 24 March 2014, 13:16 »
Just been to West London Performance Motors and the guy there says it's either turbo or valve stem seals, he reckons it's going to be the valve stem oil seals..... He said to take it in on Monday next week and he will do a cold check hot check and wet check along with compression check, he thinks that either way it will be £700 for turbo rebuilt and refitted or 6-700 for the valve stems as long as the head is okay!!
I am well gutted! Anyone on here know a mechanic that won't screw me?
Mk4 1.8T 218ps AUQ
Offline XMC1980
« Reply #54 on: 24 March 2014, 16:05 »
I have noticed there is oil on the cone inside the air box. Could this be a blocked pipe that's being pulled in by vacuum ?..?
Mk4 1.8T 218ps AUQ
Offline Nino
  • Insta - F6UGA
« Reply #55 on: 24 March 2014, 16:45 »
Have you been using the car daily before having the checks done? Odds are you had some problems that may of gotten worse.
That mechanic has given you worst case scenario please mate get it looked at by a vw specialist in your local area have you had "Stop" pop up on your dash at all? Might be a blocked oil pickup pipe starving the turbo of oil.
Offline XMC1980
« Reply #56 on: 24 March 2014, 16:50 »
I have driven it for the last 4 days, and again there is no sign of smoke now, I'm getting it recovered tomorrow to Brighton to a mechanic unless someone on the forum comes up trumps
Mk4 1.8T 218ps AUQ
Offline XMC1980
« Reply #57 on: 24 March 2014, 17:32 »
No stop light has come on, and the mechanic said I could drive it?
Mk4 1.8T 218ps AUQ
Offline GTi_James
« Reply #58 on: 24 March 2014, 21:40 »
start saving buddy
Offline Nino
  • Insta - F6UGA
« Reply #59 on: 24 March 2014, 22:43 »
Any mechanic that tells you that then says you can drive it is an idiot
