Author Topic: When life gives you lemons........? Help  (Read 87323 times)
Offline Nino
  • Insta - F6UGA
Re: When life gives you lemons........? Help
« Reply #30 on: 21 March 2014, 17:36 »
I can see what you have done so far but spending £8 on a thermostat tells me you haven't got an OEM part = BIG mistake you will be replacing that shortly...
Myself and my cuz were working on a mk2 golf gti that we bought for messing about with so we could learn a few things.
This mk2 on IDLE would bellow white smoke but once warm all was fine.
We also notice when driven all was fine.
I suggested an oil change at the time which improved it which would suggest is what the owner did to your car.
After alot of this and that the head gasket was found to be blown.
It's your car and totally upto you BUT i would get a compression test done before using that car but then thats just me.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« Reply #31 on: 21 March 2014, 17:41 »
Correction thermo is £38 and all those prices are not inc of VAT
I am getting the compression test done on Monday now after using my noddle, it has been fine again all day not one puff of smoke?
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline XMC1980
« Reply #32 on: 21 March 2014, 18:54 »
Listen before you go spending money on things you aint sure off please run a diagnostic on the car. If you was close to me in bham i would do it for you and check everything out fully.
I am at a dead end now dude! Missus says if you help me she will cook you Mexican lasagne haha
Mk4 1.8T 218ps AUQ
Offline XMC1980
« Reply #33 on: 21 March 2014, 19:28 »
Hmmmmm what will I get if I remap the car?
Mk4 1.8T 218ps AUQ
Offline Nino
  • Insta - F6UGA
« Reply #34 on: 21 March 2014, 20:28 »
Niño
Hello mate and thank you for all your advice, I went this morning to a friends garage who isn't the best but not a cowboy haha, we plugged the car in on a snap on scanner and it came back with a lambda sensor pre cat fault.
As for the oil sensor workshop warning that has been resolved, the plug had been knocked off the sump as it's low.
The car passed MOT emissions and with flying colours
As for the main concern...... Well it transpires that it's blue smoke that comes out, it's mostly when idle and when starting, once warm it's okay and under load it's not present.
Thee is no loss of coolant and no loss of oil in the last 100 miles
I ordered some bits but I'll wait until I resolve this issue first
Lambda sensor £75
Coolant temp sensor £11
Thermostat £8
Discs front £43
Pads front £30
So no compression test done yet but 2 mechanics say the head gasket looks good
Sorry i read this post you did and i thought your thermostat cost you £8 didnt realise it was a typo.
As for remapping your car i would focus on ensuring your car is running right first  :undecided:
« Last Edit: 21 March 2014, 20:30 by Nino »
Offline apollo996
« Reply #35 on: 21 March 2014, 20:53 »
This is good advice.
If it was me I wouldn't spend anything on the car until I knew what the issue is.  It could be you are throwing good money after bad.  Why not listen to the good advice people are giving you.  Getting the problem diagnosed is the priority.  Just looking at your list of parts bought already that's £200+ including VAT.  This could be money wasted if the car really is a lemon.  You may not even need all these parts but as you haven't had the problem diagnosed yet you don't know  :whistle:
« Last Edit: 21 March 2014, 20:58 by apollo996 »
Offline XMC1980
« Reply #36 on: 21 March 2014, 21:16 »
Guys I do appreciate your advice and I have ordered the parts to be in store but not paid for them yet, the plan is is to resolve the issue first but I can't do anything now until Monday when I get the comp test done, maybe I'm being optimistic
I have been recommended to a guy called Mo at West London Performance Motors?
Mk4 1.8T 218ps AUQ
Offline gazareth
« Reply #37 on: 22 March 2014, 01:27 »
hey dave. hows it going?
Offline XMC1980
« Reply #38 on: 22 March 2014, 17:56 »
Not a puff of smoke for 2 days oil and water haven't moved :undecided: wtf!!!
Mk4 1.8T 218ps AUQ
Offline sharki786
  • GOT BOOST??
« Reply #39 on: 22 March 2014, 18:35 »
Was the car by any chance parked up for some time?
*****MK3 Anniversary*****
*****MK4 GTI T*****
