Author Topic: VW Golf 7 Fog lights How to Activate VCDS Please Help!  (Read 19405 times)
Offline cebbes30
hello,
i have install the fog lights in my car vw golf 7 thru the circuit diagram that was easy.
Olso install a licht switch wit fog lichts.
But i dont now how i can activate this thru vag com,
Can anyone tell me how i can do this!
regards From Holland :angry:
Offline jivemonkey
Re: VW Golf 7 Fog lights How to Activate VCDS Please Help!
« Reply #1 on: 15 January 2014, 14:09 »
Greetings cebbes30
This could go either way, either fairly simple to do or quite complex (There are many many light configuration adaptation channels in the central electrics module, which is where it may need to be done). Also something to bear in mind is that the GTI/D has LED fogs, so the values in this part of the adaptation channel may not be suitable unless you're installing genuine GTI/D white LED fogs. Is this what you're doing? We need some more information about your vehicle in order to try and help. Could you provide an auto
scan?
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline cebbes30
« Reply #2 on: 15 January 2014, 19:22 »
Hello Jivemonkey,
I have a golf 7 1.2 TSI trendline, 86 pk, Discover Media NAVI, winter package, parking sensors, seat heating, SRA, rainsensor/lightsensor, dimming mirror, Alarm plus, foldable mirrors with environment lichts with folding thru remote, coming home leaving home. and fog lights normal not a LED version.
Options rainsensor/lightsensor, dimming mirror, alarm plus, foldable mirrors, coming home en leaving home a have install it en recode it by myself!
The only thing i cant find is how a recode the fog lights.
What i have notice is when its day and i pull the lichtswitch to fog lights the dim headlight wil go on.
When its evening and dark and i pull the fog lights nothing happens???
Please i need help because i have install it and cant use it frustrates me!!!!!
This is a scan of my car.
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CJZB)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 E    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 4972
   Revision: WAH08---
   Coding: 01110032230411082000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM12TFS01104E906016E 001006
   ROD: EV_ECM12TFS01104E906016H.rod
   VCID: 24470A1B2F2E243ED0B-8071
No fault code found.
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 D    HW: 5Q0 907 379 D
   Component: ESC           H75 0433
   Revision: 00000000    Serial number:
   Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F300280028C0
   Shop #: WSC 00028 028 00024
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 3D71DF7FAC8475F6BF5-8068
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020004200100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 3663C05389B2A6AE7EF-8063
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 L    HW: 5Q0 937 084 L
   Component: BCM MQBAB H   H14 0103
   Serial number: 00011227800350
   Coding: 000C0846C24502FB0FA44080B11C07080000000000000000000000000000
   Shop #: WSC 00028 028 00001
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 4189A38FD07C1116DBD-8014
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A
   Component: WWS    120910  042 0551
   Serial number:         120924160900
   Coding: 0E4DD5
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
   Component: RLFS  024 0042
   Serial number: Y12M07D17H08M26S20S4
   Coding: 028877
   Subsystem 5 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY131081RVJ
   Subsystem 6 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000056969920
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231228307836
   Coding: 0031051001
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 3A7BD463BDAA42CE9A7-806F
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R00E6ZJ
   Coding: 98CCC000000000005C0000CF004800000065
   Shop #: WSC 00028 028 00057
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 408FA68BDB76181ED43-8015
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 000 310 12
   Component: SideSensor_Df  001 0887
   Serial number: 35767000000E2845EB00
   Coding: 2D2D2D
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 480 000 810 12
   Component: SideSensor_Pf  001 0887
   Serial number: 3586700000042729DB0Y
   Coding: 2D2D2D
   Crash sensor for side airbag; rear driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 400 910 12
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502A90D19C31C0EK
   Coding: 2D2D2D
   Crash sensor for side airbag; rear passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502AD0CD5EB313CY
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 210 12
   Component: FrontSensor_D  001 6149
   Serial number: 3556502B30CD5EB4531M
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 1510120003004H
   Coding: 0400
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB.rod
   VCID: 75E1075FD434EDB6B75-8020
Address 17: Instruments (J285)       Labels: None
   Part No SW: 5G0 920 860     HW: 5G0 920 860
   Component: KOMBI         235 0555
   Coding: 07A402002380000800086A00040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: E5C1D71FE4949D36875-80B0
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1109
   Revision: --------    Serial number: 0000104516
   Coding: 030100042B086400EF000648080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_VW37.rod
   VCID: 3365F9479AC0B386591-8066
   Generator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5G0 959 442 H    HW: 5G0 959 442 H
   Component: E221__MFL-DC1  H12 0034
   Serial number: 23120002038210080291
   Coding: 240000
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 5430458201
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593 A
   Component: TSG FS        H12 0006
   Serial number: 20091200010349
   Coding: 001B0220D000040000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 3F8DA577A68867E6AD9-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Component: Fond FHSG DRV  007 0002
   Serial number: 00000000000000243883
   Coding: 010000
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ASAM Dataset: EV_SteerAssisMQB 008022
   ROD: EV_SteerAssisMQB.rod
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       H12 0006
   Serial number: 03081200010093
   Coding: 001B0020DE00040000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 3E73D873A1826EEEA6F-806B
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Component: Fond FHSG PSG  007 0002
   Serial number: 00000000000000247280
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5G0 035 846     HW: 5G0 035 846
   Component: MU-S-N-ER     038 0130
   Serial number: V1F01510120522
   Coding: 02730001FF00000011110001000800001F0100840100010045
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: E6C3D0131992962E8EF-80B3
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H44 0020
   Serial number: VWZ8Z9M340050A
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 F    HW: -----------
   Component:  ECE 2014  --- 0036
   Serial number: --------------------
Offline jivemonkey
« Reply #3 on: 15 January 2014, 19:55 »
Thanks for the info. I've had a look in to it, can you tell me what values you have for the following adaptation channels in Central Electrics [09]?
Leuchte12NL LB45-Lasttyp 12
Leuchte12NL LB45-Lichtfunktion A 12
Leuchte13NL RB5-Lasttyp 13
Leuchte13NL RB5-Lichtfunktion A 13
Offline cebbes30
« Reply #4 on: 15 January 2014, 20:09 »
i go down stair to my car one moment
Offline cebbes30
« Reply #5 on: 15 January 2014, 20:32 »
This is the point results of the Netherlands :laugh:
Leuchte12NL LB45-Lasttyp 12  NOT ACTIVE
Leuchte12NL LB45-Lichtfunktion A 12 NOT ACTIVE
Leuchte13NL RB5-Lasttyp 13  NOT ACTIVE
Leuchte13NL RB5-Lichtfunktion A 13  NOT ACTIVE
Offline cebbes30
« Reply #6 on: 15 January 2014, 21:40 »
Offline jivemonkey
« Reply #7 on: 16 January 2014, 10:47 »
Interesting. These are the light addresses that are used for the fog light on my Golf, the Lasttyp (type of light) is set as '6 - LED Lichtmodul' which is for the aforementioned LED fog lamps. You would need to check another car which has the halogen fog lights to see what type is used to make sure you get the right one, or check the available options and see if you find a suitable one. Wouldn't recommend that!
If it helps, here is what's set for fogs:
Left Fog:
(1)-Leuchte12NL LB45-Lasttyp 12                                               6 - LED Lichtmodul
(2)-Leuchte12NL LB45-Lampendefektbitposition 12                           38
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12      22
(4)-Leuchte12NL LB45-Lichtfunktion A 12                                      Nebellicht links
(5)-Leuchte12NL LB45-Lichtfunktion B 12                                      not active
(6)-Leuchte12NL LB45-Dimmwert AB 12                                      127
(7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12                      Always
Right Fog:
(1)-Leuchte13NL RB5-Lasttyp 13                                              6 - LED Lichtmodul
(2)-Leuchte13NL RB5-Lampendefektbitposition 13                      42
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13      23
(4)-Leuchte13NL RB5-Lichtfunktion A 13                                      Nebellicht rechts
(5)-Leuchte13NL RB5-Lichtfunktion B 13                                      not active
(6)-Leuchte13NL RB5-Dimmwert AB 13                                      127
(7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13                      Always
You will need to try and compare with someone with halogen fogs to find out correct values for the entries in bold.
Also, double check the 'Lasttyp' is the same (12 for left fog, 13 for right fog) for non-LED fogs.
Let me know how you get on. Good luck!
Offline cebbes30
« Reply #8 on: 16 January 2014, 11:44 »
Hello Thanks, i will look for it.
But if i find the proper valeu i can change that and everthing works??
Or do i need more to change under adaption!
Maybe members who have normal fog light can help me here, so i ask ther help olso
Offline jivemonkey
« Reply #9 on: 16 January 2014, 12:12 »
You're welcome.
I can't guarantee that more coding will not be required, as I've only had a look at what my Golf has and compared it with yours, VCDS coding isn't an exact science unfortunately. I would say that it is definitely a step in the right direction though!
