Author Topic: VW Golf 7 Fog lights How to Activate VCDS Please Help!  (Read 19406 times)
Offline jivemonkey
Re: VW Golf 7 Fog lights How to Activate VCDS Please Help!
« Reply #10 on: 16 January 2014, 14:06 »
Whilst looking through an old thread relating to the unfolding of wing mirrors on unlock, I came across this screenshot from Noobmonkey which had foglight associated entries.
Worth checking to see if these are set correctly for you too, they would have been unchecked from the factory.
It's the central electronics module [09] long coding byte 7, so you'll need to enter the access code first to change (31347).
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline cebbes30
« Reply #11 on: 16 January 2014, 14:50 »
Yes i have saw that.
if i dont check  the fog lights switch the bcm give a lite error after accepting the light error gas gone.
thanks ..
Offline jivemonkey
« Reply #12 on: 16 January 2014, 14:56 »
Okay, well that should be all you need in the central electrics long coder. I have posted elsewhere as well for someone with halogen fogs to post their adaptation channels, but nothing yet.
Did the wiring instructions that came with the fogs state any light number or circuit number that they will be connected to? Was the wiring already in place? What type of bulb is it? What is the power rating? These might help identify the correct 'load type' to choose in the adaptation channels mentioned earlier.
Offline cebbes30
« Reply #13 on: 16 January 2014, 17:52 »
I have done it.
thanks to you and Wonni from germany.
Both of you give info so i have let it work.
olso i have made when i turn the fog lichts go on.
only thing what i cant change is.
2 lampendefectposition.
3 fehlerort mittleres
please enter one hexadecimal byte, eg: FF
« Last Edit: 16 January 2014, 18:08 by cebbes30 »
Offline cebbes30
« Reply #14 on: 16 January 2014, 21:24 »
Hello Jivemonjey,
Can you tell me how i can enter the numbers.
PLEASE ENTER A HEXADECIMAL BYTE.
HOW CAN I  RECOUNT THIS? To the valeus 22 ore 38.
Offline jivemonkey
« Reply #15 on: 16 January 2014, 21:52 »
Hello Jivemonjey,
22 is binary 10110, which is 0x16 (hex), 38 is binary 100110, which is 0x26 (hex).
Where are you sticking these?
Offline cebbes30
« Reply #16 on: 16 January 2014, 22:07 »
Hello
when i want to put 22 or 38 the give me a error.
fehlerort mittleres         0 0
lampendefectposition   00
« Last Edit: 16 January 2014, 22:10 by cebbes30 »
Offline cebbes30
« Reply #17 on: 17 January 2014, 07:48 »
Hello Jivemonkey
i had one little isseu maybe you can give me a hint.
i have the option when i drive above 15 km the doors wil auto lock
thats work fine.
but when i unlock from the switch the yellow licht go of and when pull the door handle the unlock again.
when i shut the 15 km above option i can lock and unlock no problem.
i have put the old door code back to both doors.
isseu resolve but then i cant actived the option folding mirrors anymore.
even deactivate mirror folding in adaption and again actived with the old code wont work to folding mirrors.
now with the curent door code i can fold with the remote one push.
do you have any sugestions?
Offline cebbes30
« Reply #18 on: 25 January 2014, 21:19 »
hello
i have a question.
when the light switch is on AUTO en the lights are ON in the evening and when i shift to reverse the fog lights go ON till go forward again.
when i switch the right and left turnlights the fog lights olso go on left ore right what direction you push.
this is only when the lights are ON.
is this normal?
even the
Offline cebbes30
« Reply #19 on: 11 February 2014, 22:53 »
Hello,
I want to close this Topic,
Its working fine, only thing i cant put the 22 and 38 values.
(2)-Leuchte12NL LB45-Lampendefektbitposition 12                                  38
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12                    22
This is now the value
fehlerort mittleres       00
