Author Topic: VW Golf 7 Fog lights How to Activate VCDS Please Help!  (Read 19406 times)
Offline cebbes30
Re: VW Golf 7 Fog lights How to Activate VCDS Please Help!
« Reply #20 on: 24 February 2014, 19:35 »
Hello,
I have get today a update to my car by the vw garage.
After update
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 L
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011227800350
   Coding: 00040846C24102FB0BA44080B11C07081000000000000000000000000000
   Shop #: WSC 13107 102 209715
   ASAM Dataset: EV_BCMCONTI 011001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 77FD0D57CE389FA6A59-8022
Before update
   Part No SW: 5Q0 937 084 L    HW: 5Q0 937 084 L
   Component: BCM MQBAB H   H14 0103
   Coding: 000C0846C24102FB0FA44080B11C07080000000000000000000000000000
   Shop #: WSC 00028 028 00001
   ASAM Dataset: EV_BCMCONTI 010001
   VCID: 4189A38FD07C1116DBD-8014
The problem wit the update is that all personel adjusment are gone.
So i have manage that back to befor update, only one thing i cant get work.
The static cornering lights!!!
Left Fog:
(1)-Leuchte12NL LB45-Lasttyp 12                                              10 - Normal schienwerfer
(2)-Leuchte12NL LB45-Lampendefektbitposition 12                           00
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12            00
(4)-Leuchte12NL LB45-Lichtfunktion A 12                                      Nebellicht links
(5)-Leuchte12NL LB45-Lichtfunktion B 12                                      not active ??????
(6)-Leuchte12NL LB45-Dimmwert AB 12                                      100
(7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12                      Always
Right Fog:
(1)-Leuchte13NL RB5-Lasttyp 13                                             10 - Normal scheinwerfer
(2)-Leuchte13NL RB5-Lampendefektbitposition 13                      00 Cant cjange this
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13      00 Cant change this
(4)-Leuchte13NL RB5-Lichtfunktion A 13                                      Nebellicht rechts
(5)-Leuchte13NL RB5-Lichtfunktion B 13                                      not active ????
(6)-Leuchte13NL RB5-Dimmwert AB 13                                      100
(7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13                      Always
Can anyone tell me what i need to change, static cornering is a nice futere and want this back..
I dont now anymore what i have done!
Offline cebbes30
« Reply #21 on: 24 February 2014, 21:19 »
Hello
I have resolve it, the problem was the car mus not be running! when you want to recode this.
after turning the ignition to ON i have enable this!
5.Kanal (5) Leuchte12NL LB45-Lichtfunktion B12 auswählen
6.Wert auf Abbiegelicht links anpassen
7.Kanal (5) Leuchte13NL RB5-Lichtfunktion B13 auswählen
8.Wert auf Abbiegelicht rechts anpassen
