Author Topic: Gearbox  (Read 25170 times)
Offline Mcwill
Re: Gearbox
« Reply #20 on: 15 January 2014, 23:50 »
Another option that's for sale on ebay is a g60 gearbox code cba, fast through the gears but longer in 4th and 5th. 156 mph in 5th :laugh:
Offline gazareth
Re: Gearbox
« Reply #21 on: 16 January 2014, 00:12 »
the 8v gti box is closer ratio than the cba box which is better suited to a revvy 16v engine. it all comes down to how you want to drive it though. top speed or acceleration???
Offline Mcwill
Re: Gearbox
« Reply #22 on: 16 January 2014, 00:19 »
I want best of both  :smiley:
Offline weazgti
Re: Gearbox
« Reply #23 on: 16 January 2014, 10:31 »
Is it run in yet?
Offline Mcwill
Re: Gearbox
« Reply #24 on: 16 January 2014, 15:31 »
I've done about 1000 miles in it since rebuild so yeah it should be.
Offline Gambit
Re: Gearbox
« Reply #25 on: 16 January 2014, 16:50 »
did you ever find out what the code is of the box currently fitted? just because you think its an 8v box doesnt mean it is....i once had a 16v that came with a Maestro box - yes an Austin Maestro box!!
Offline Mcwill
Re: Gearbox
« Reply #26 on: 16 January 2014, 18:47 »
Haha my dad used to have one of them, heap of crap.
Think it's an 8v as it was a 8v clutch that the garage got for it when they did the engine.
It's maybe me thinking it was going to be faster then it is. :undecided:
But I have seen some YouTube vids of abf mk2s and they look faster.
Offline Gambit
Re: Gearbox
« Reply #27 on: 16 January 2014, 20:38 »
Your missing the point. All 1.6, 1.8, driver, gti, gl & diesel all use the same 8v clutch on a variety of gearboxes with different ratio's and all boxes fit hence until you get the gearbox code of the bottom of the bellhousing you dont know what is in it
Offline Mcwill
Re: Gearbox
« Reply #28 on: 16 January 2014, 21:35 »
Ill find out what code it is next time I'm under the car.
What gearbox/ code would you use gambit?
Offline Gambit
Re: Gearbox
« Reply #29 on: 16 January 2014, 21:43 »
You'd want an AUG box imo - closest to a 16v box but with a slightly longer 5th
this is a listing of all rod boxes and their ratio's ( http://www.scirocco.org/gears/) hence find out what yours is.
