Author Topic: Gearbox  (Read 25168 times)
Offline Mcwill
Gearbox
« on: 07 January 2014, 23:34 »
Running the 8v gearbox on my mk2 abf but don't like the gear ratios as it feels sluggish in the gears almost like there to long. Been looking on the net and there seems to be lots of options and opinions on what the best set up is but nobody seems to agree.
I don't want to change to hydraulic set up so what's best to go for, 02a seems to get mentioned a bit?
Would it be worth getting 8v box rebuilt with different ratios?
Any advice would be great thanks.
Offline Mcwill
Re: Gearbox
« Reply #1 on: 11 January 2014, 07:39 »
Anybody?
Would it be possible to have the 8v box reconditioned with different gear ratios? And what sort of power can that box withstand?
Any help or advice would be great.
Offline dai-cymru
  • 1989 MK2 16V
Re: Gearbox
« Reply #2 on: 11 January 2014, 08:14 »
The cost of getting the ratios changed I would suggest its prob cheaper to source a good o2A box and fit that
Offline Mcwill
Re: Gearbox
« Reply #3 on: 11 January 2014, 13:57 »
What golf is the 02a box on and is it cable clutch?
Offline weazgti
Re: Gearbox
« Reply #4 on: 11 January 2014, 20:40 »
I ve read that people think it feels slower with the 02a box compared to the 8v. I mean obviously it will last with the correct gearbox but it sort of put me off changing mine. I have same as you 8v box on abf lump. O2a in the shed still.
Offline Mcwill
Re: Gearbox
« Reply #5 on: 12 January 2014, 01:45 »
With mine as it is at the mo I'm getting about 60mph in 2nd 80mph 3rd 100mph 4th and 133mph 5th. Dose that sound about rite?
Any guys out there running 02a box on abf lump? What you guys get?
Offline weazgti
Re: Gearbox
« Reply #6 on: 12 January 2014, 10:31 »
I get nearly 95mph in 3rd @6900rpm with 8v box although I wouldn't trust the 24 year old clocks in it.
No idea wot it does in 4th because it's the Isle of Wight and only short blasts.
Offline gazareth
Re: Gearbox
« Reply #7 on: 12 January 2014, 19:23 »
maybe your engine needs fine tuning? for all the difference there is in the ratios I would just leave the 020 in until it falls to bits. maybe the engine is still a bit tight after the rebuild.
Offline Mcwill
Re: Gearbox
« Reply #8 on: 12 January 2014, 21:41 »
Not sure what to do? Think ill leave for now and let engine get a few miles on it.
Was thinking of taking it down my local rolling road and having it tunned but seems bit pointless until I get gearbox sorted.
Offline gazareth
Re: Gearbox
« Reply #9 on: 13 January 2014, 00:46 »
 I think your just not revving the engine hard enough :wink:. I would get it on the dyno first just to make sure its making good power. the gearbox may not be the issue.
