Author Topic: What is the best turbo to upgrade to?  (Read 6784 times)
Offline paul yeo
« on: 27 November 2013, 21:17 »
Hi I have a 2000 w reg 1.8t with a arz engine code. I'm looking for a bit more power and was wondering about swapping the turbo for a k04. How easy is this? Is it bolt on or is it like everything vw and not that simple. Thanks in advance
Offline barrym381
Re: What is the best turbo to upgrade to?
« Reply #1 on: 27 November 2013, 21:51 »
get a k300 hybrid from a user on here  :wink:
Offline rio_gti
« Reply #2 on: 27 November 2013, 21:52 »
How much is a bit more power?
Offline mcgee9t2
« Reply #3 on: 27 November 2013, 23:23 »
depends what you want. how much power and how much money you want to put into it.
if you want a cheep bit more power get a k03s and a map
if you want more then look at hybrids such as k03 with tt225 compressor wheel, will see up to 270 ish with that.
or if your fixed on k04 then look at the k04-025 I think it is that's a direct bolt on, some are bolt on some require different manifolds
Offline golfyste
  • Project track car
« Reply #4 on: 27 November 2013, 23:42 »
K03s and mods or k300 from beach buggy turbos and same relevant mods for 300bhp
K04 is pointless nowadays as the max ever produced from a k04 is 313 bhp but average is 280 - 300bhp but you also have to get a different downpipe and oil/water lines, tip and charge pipe
So k300 ftw!
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
« Reply #5 on: 28 November 2013, 02:41 »
So k300 ftw!
Nar mate i ran 311bhp at R Tech"s rolling road day last month, and I'm having a custom inlet manifold built by good old Bill at Badger5, and a 57mm ABD Racing big bore intake tube fitted at the same time, which will see it well past 313bhp  :grin:
I'll smash that record if its true !!!
Will put dyno pics up to prove as well
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
« Reply #6 on: 28 November 2013, 02:44 »
It was 310bhp at R Tech but ill still smash that record  :grin:
Offline navmk4gti
« Reply #7 on: 28 November 2013, 03:47 »
How you putting all that power down on a fwd.. you must have some serious wheel spin  :grin:
Offline paul yeo
What turbo is the best to upgrade to
« Reply #8 on: 28 November 2013, 08:08 »
Don't wanna spend crazy money to be fair and would like to see 200bhp. Got a front mount intercooler, re circ valve and 4.0 bar fuel pressure reg. Wondering if a re map on the standard turbo would be the best option or upgrade turbo then re map
Offline golfyste
  • Project track car
« Reply #9 on: 28 November 2013, 08:34 »
Get a k03s  and get rid if the 4bar for for a standard 3 bar one and get a exhaust, tip and custom map and hit 225+  :smiley:
