Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120866 times)
Offline GrahamFR
Re: MK7 and VCDS (VAG-COM) thread
« Reply #440 on: 17 February 2014, 20:03 »
I had to reboot after a while but I still got the error message on drl brightness which is annoying as that's the one I really want!
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline Golfmk7
« Reply #441 on: 17 February 2014, 20:32 »
I really dont no any more how to do it so i orderd
http://www.kufatec.de/shop/en/volkswagen/golf/golf-7-5q/coding-dongle-footwell-lighting-mqb
Hope it will work for now or else i kill my car.
Offline itavaltalainen
« Reply #442 on: 17 February 2014, 20:33 »
Before you plug the dongle in undo all your coding, run a scan, then run another after using dongle.
This might help to work out what needs doing....
Offline xzer0
« Reply #443 on: 17 February 2014, 20:50 »
Hello everyone!
I have got that "Channel Not Available" error before. In my case I just reopened the channel, entered security mode (31347 !!!), and repeated the procedure. At the end you can still try to reinstall the VCDS.
Hope you all resolve the issue.
Mike
mk7 GTI Performance
Offline Golfmk7
« Reply #444 on: 17 February 2014, 20:59 »
Ok thats a good idea!
I let u no when the dongle arrives!
Offline jivemonkey
« Reply #445 on: 18 February 2014, 08:41 »
What cable are the guys using that can't access the channel? Only last night I changed these same channels and more without problem. Are any channels in that range selectable for you?
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline GrahamFR
« Reply #446 on: 18 February 2014, 11:26 »
I borrowed the one at Shark's so I assume old cable to real up-to-date software, what difference does the cable make?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline karlak
« Reply #447 on: 18 February 2014, 11:29 »
It may be worth mentioning again.
Some "3rd party" none Rosstech cables will not have the full functionality of the genuine article.
Ordered 06/01/14.  5DR GTD DSG, Red. Park Assist | Rear Camera | Keyless entry | Dynaudio | Winter Pack | Pro Nav.
Offline GrahamFR
« Reply #448 on: 18 February 2014, 11:34 »
That sounds like fubar, surely a cable is a cable, if i buy a usb charger for my phone from ebay for £2 it will charge my phone as well as a usb charger direct from Sony (Xperia, surprisingly nice alternative to Samsung Galaxy...)
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline karlak
« Reply #449 on: 18 February 2014, 11:44 »
Fubar ?
Nope, there are numerous forum posts where a cheaper cable does not have full functionality.  The VCDS is more that a "cable" you cant for a second compare it to a UBS lead.... It is designed to work with the VCDS software and is recognised by a unique serial number.
