Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1121038 times)
Offline Golfmk7
Re: MK7 and VCDS (VAG-COM) thread
« Reply #420 on: 16 February 2014, 19:19 »
where did you get the parts? you said there were instructions with it?
maybe you have a link to that?
maybe post a full auto scan here (attach a text file)
This is the part i bought from kufatec.
Autoscan i sent in half hour.
http://www.kufatec.de/shop/de/volkswagen/golf/golf-7-5q/kabelsatz-furaumbeleuchtung-front-vw-golf-7
Offline Golfmk7
« Reply #421 on: 16 February 2014, 20:06 »
ok i have a autoscan for u,  :smiley:
do i have to mount a fuse on the fusebox? the manual says notting about it.
thanks a lot!!
Sunday,16,February,2014,20:38:20:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69 A5
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CRKB)       Labels: None
   Part No SW: 04L 906 021 FD    HW: 04L 907 309 E
   Component: R4 1,6L EDC   H22 5714
   Revision: 86H22---
   Coding: 01190032033405092000
   Shop #: WSC 11863 000 1048576
   ASAM Dataset: EV_ECM16TDI01104L906021FD 002002
   ROD: EV_ECM16TDI01104L906021FD_VW37.rod
   VCID: 6CD7223B877E2C7E58B-8039
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 S    HW: 5Q0 907 379 G
   Component: ESC           H31 0456
   Revision: 00000000    Serial number: 617030000008F5
   Coding: 01FA62A1242509710379060441CB2580462490C06082A4F30040F076C002
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 4C9782BBE73ECC7E38B-8019
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00020104202100011105000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003018
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 387FCE6B83A650DE6C3-806D
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011318101695
   Coding: 00020E42C2C122FB4BE44080B10C07081008000000000000000000000000
   Shop #: WSC 11863 123 104857
   ASAM Dataset: EV_BCMCONTI 011001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 77FD0D57CE389FA6A59-8022
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A
   Component: WWS    130626  042 0551
   Serial number:         130628214010
   Coding: 0E4DDD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
   Component: RLFS  024 0042
   Serial number: Y13M06D25H15M08S43S4
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY131560H3W
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000057249951
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131317700401
   Coding: 0031061141
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_AU37.rod
   VCID: 3D71DF7FAC8475F6BF5-8068
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R03UJU6
   Coding: 98CCC000000000005C0000CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4A9B84A3ED4AD24E0A7-801F
   Seat belt tensioner; left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667B02071370478
   Coding: 333135
   Seat belt tensioner; right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668B01071350580
   Coding: 333135
   Crash sensor for side airbag; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 406 13
   Component: SideSensor_Df  001 0887
   Serial number: 3576700000067C215D0V
   Coding: 2D2D2D
   Crash sensor for side airbag; passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 406 13
   Component: SideSensor_Pf  001 0887
   Serial number: 358670000000B7A05D0W
   Coding: 2D2D2D
   Crash sensor for side airbag; rear driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 402 706 13
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502A710CBDD483CU
   Coding: 2D2D2D
   Crash sensor for side airbag; rear passenger side:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 006 13
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502A7106FA22C0EG
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 006 13
   Component: FrontSensor_D  001 6149
   Serial number: 3556502B7106FA23F02C
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 27061304401858
   Coding: 0C00
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB.rod
   VCID: 7BF51167F210BBC6C11-802E
Address 17: Instruments (J285)       Labels: None
   Part No SW: 5G0 920 871 A    HW: 5G0 920 871 A
   Component: KOMBI         304 3380
   Coding: 07A51A006B90000800087A02040000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB.rod
   VCID: 285F1E2B5306C05EFC3-807D
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000695428
   Coding: 030100340B087300EF00064E080F00010001000000000000000000000000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_GatewLear 009013
   ROD: EV_GatewLear_VW37.rod
   VCID: 3B75D167B2907BC6811-806E
   Generator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
   Component: E221__MFL-DC1  H14 0035
   Serial number: 27130000842500123243
   Coding: 280000
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 8517290803
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 19061303111044
   Coding: 00310320D000048000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 3F8DA577A68867E6AD9-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Component: Fond FHSG DRV  007 0002
   Serial number: 00000000000001874233
   Coding: 010000
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 13
   ASAM Dataset: EV_SteerAssisMQB 008022
   ROD: EV_SteerAssisMQB.rod
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 23061301100904
   Coding: 00310120DE00048000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 3E73D873A1826EEEA6F-806B
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Component: Fond FHSG PSG  007 0002
   Serial number: 00000000000001859387
   Coding: 090000
Address 55: Xenon Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0080
   Revision: --------    Serial number: --------------
   Coding: 028A00104F000200
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A
   Component: LeiMo links  H05 0012
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A
   Component: LeiMo rechts  H05 0012
   Coding: 900000
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Component: MU-S-N-ER     040 0421
   Serial number: V1F02906131410
   Coding: 02730001FF00000021110001000800001F0100040100010047
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 275D1D175E18CF26F59-8072
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H44 0020
   Serial number: VWZ8Z9N34028DD
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 E    HW: -----------
   Component:  ECE 2013/14  --- 0034
   Serial number: --------------------
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383     HW: 5Q0 907 383
   Component: Anheanger     H10 0030
   Serial number: 00006789000000
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctDemouHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: F4E7BA5B5F4E74BE00B-80A1
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0050
   Serial number: 00000078134
   Coding: 0100020001020304000400000000000101
   ASAM Dataset: EV_MFKBoschAU370 001001
   ROD: EV_MFKBoschAU370.rod
   VCID: 3A7BD463BDAA42CE9A7-806F
End   ---------------------------------------------------------------------
« Last Edit: 16 February 2014, 20:27 by Golfmk7 »
Offline Golfmk7
« Reply #422 on: 16 February 2014, 20:08 »
and here are the pictures!
i have the manual also.
http://www.mijnbestand.nl/Bestand-QIJMMHLWORPT.pdf
« Last Edit: 16 February 2014, 20:19 by Golfmk7 »
Offline itavaltalainen
« Reply #423 on: 16 February 2014, 22:37 »
UNTICK bit 7 in byte 5!
Offline cebbes30
« Reply #424 on: 17 February 2014, 06:04 »
Hoi,
Ik zag je post voorbij komen en wil dit zelf ook gaan doen, kunt u aangeven is het lastig om de BMC eruit te halen, als ik zo de foto`s zie wel.
Ik heb eigenlijk nog één vraag heeft u ook cruise control geinstalleerd op u auto orgineel via de stuur zonder ACC dus met de tekst DCL op linker deel van het stuur.
Mvg
Yuri
Offline Golfmk7
« Reply #425 on: 17 February 2014, 07:32 »
Hi, thanks for your help.
I also tried. still does not work.  :sad:
do not know what I can do about it.  :cry:
« Last Edit: 17 February 2014, 07:34 by Golfmk7 »
Offline Golfmk7
« Reply #426 on: 17 February 2014, 08:00 »
is it maybe my BCM not ok? i mean not supported?
i have a bluemotion highline version.
Offline Jimble
  • Moderator
« Reply #427 on: 17 February 2014, 08:19 »
Hoi,
Mvg
Yuri
Could you please say that again in English to benefit the whole forum.
Thanks :smiley:
« Reply #428 on: 17 February 2014, 08:28 »
What, highline comes without footwell lights in Holland?
You seem to have different central electrics from my car... but would be surprised if it would not support footwell lights
Possibly needs something else activating in adaptation... one of the many lights settings with only letters and numbers
Offline cebbes30
« Reply #429 on: 17 February 2014, 08:32 »
Hi,
I saw your post come over and want to now, you can indicate if its difficult to do it.
I want to now did your car have cruise control installed through the original steering without ACC so the text DCL left part of the steering wheel.
Mvg
Yuri
Hoi,
Mvg
Yuri
Thanks :smiley:
