Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120867 times)
Offline Golfmk7
Re: MK7 and VCDS (VAG-COM) thread
« Reply #430 on: 17 February 2014, 09:19 »
What, highline comes without footwell lights in Holland?
You seem to have different central electrics from my car... but would be surprised if it would not support footwell lights
Possibly needs something else activating in adaptation... one of the many lights settings with only letters and numbers
hahahah in holland is everything based on money  :grin:
how can i find wich adaption i have to change?
Offline Golfmk7
« Reply #431 on: 17 February 2014, 11:54 »
I was searching on the internet about the problem i have.
I got something but from a anathor brand (Audi), but seemed very much.
http://forums.vwvortex.com/showthread.php?4468565
maybe this is the solution?
so yes how to do it?
« Last Edit: 17 February 2014, 13:02 by Golfmk7 »
Offline noobmonkey
« Reply #432 on: 17 February 2014, 16:40 »
Pretty sure that's not based on the same hardware, letaone platform? :| - good hunting, but i'm running out of thoughts on this one!
VW Golf MK7 GTD Manual 5DR Pure White
Offline Golfmk7
« Reply #433 on: 17 February 2014, 16:44 »
Pleaseeeee i am running out also :cry:
Offline Ian.C
« Reply #434 on: 17 February 2014, 16:58 »
Hi all. I've been conversing with a new member mihaelo1 (Michael) via PM, and he's just sent me some details and photos of a VCDS mod that he and his friends have just done to the LED tail lights on their GTI.
Basically, using this coding allows the high intensity brake light function to operate not just on the outside clusters, but also on the inboard (boot mounted) clusters.
I haven't tried this myself yet, however Michael provided the coding and very kindly allowed me to post here along with his photos.
Coding
STG09 (Central Electronics)> Access Authorisation: 31347 > Adaptation Channels> Channel (8 )-Leuchte27 NSL RC6-Lichtfunktion C27" > "Brake light on" set (default: nicht aktiv)
 STG09 (Central Electronics)> Access Authorisation: 31347 > Adaptation Channels > Channel (10)-Leuchte27 NSL RC6-Dimming CD27" > on 100 Set(default: 0)
Images
1 by Sootchucker, on Flickr
2 by Sootchucker, on Flickr
33 by Sootchucker, on Flickr
45 by Sootchucker, on Flickr
All thanks go to mihaelo1  (Michael) and his friends for this one. Enjoy.
Hi there
Im trying to code this mod and my VAGCOM is telling me the channel isnt available....has anyone managed to carry out this mod...??
Thanks
Ian
3 Door - Pure White - PP
Offline GrahamFR
« Reply #435 on: 17 February 2014, 17:33 »
yeah i tried this and the drl brightness to 100 at shark the other day, it wouldnt let me do either, i believe the message i got was format error or something when i tried to put a value in, at least that was for the drls, i cant remember what it said for the brake lights but i know they both didnt work!
Anyone fancies remedying this one for me would be grateful!
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline Ian.C
« Reply #436 on: 17 February 2014, 18:15 »
OK thanks....at least it isnt just me
Ian
Offline KyleB
« Reply #437 on: 17 February 2014, 19:46 »
I've had channel unavailable errors before. Needed to reboot my laptop as it was happening on all modules.
Offline Ian.C
« Reply #438 on: 17 February 2014, 19:56 »
OK ill give it another go tomorrow....Have you done this Mod Kyle..??
Thanks
Ian
Offline Ian.C
« Reply #439 on: 17 February 2014, 20:02 »
On another subject....ive bought the parts to fit heated washer jets and had a look around in VCDS and found this......
Can I assume this is the adaption I need to activate the jets after I install the wiring and new washer jets.
Thanks
Ian
