Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120872 times)
Offline GrahamFR
Re: MK7 and VCDS (VAG-COM) thread
« Reply #450 on: 18 February 2014, 12:16 »
It may be worth mentioning again.
Some "3rd party" none Rosstech cables will not have the full functionality of the genuine article.
That sounds like fubar, surely a cable is a cable, if i buy a usb charger for my phone from ebay for £2 it will charge my phone as well as a usb charger direct from Sony (Xperia, surprisingly nice alternative to Samsung Galaxy...)
Fubar ?
Nope, there are numerous forum posts where a cheaper cable does not have full functionality.  The VCDS is more that a "cable" you cant for a second compare it to a UBS lead.... It is designed to work with the VCDS software and is recognised by a unique serial number.
I dont mean to use a usb instead of a vcds cable, what i mean is, like a usb, the cable allows the software to read the ecu, so surely a chinese copy can do the same thing. It either works or it doesnt, i dont see how a cable can just 'work a bit', you can get hdmi cables that just work a bit, its either there or it aint?
But anyway, im detracting from what i really want to know. If you use a cable (OEM) for vag-com 5.something, that can still work fine on vcds 12.whatever we are?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline Golfmk7
« Reply #451 on: 18 February 2014, 12:29 »
hello you all!
does anyone have a diagram of the fuses?
Offline Golfmk7
« Reply #452 on: 18 February 2014, 19:38 »
Nobody?
Offline itavaltalainen
« Reply #453 on: 18 February 2014, 20:03 »
Fubar ?
The ebay knock offs will not work with Ross-tech software, they rely on a hacked/cracked version... so no not the cable is the problem necessarily (but who knows what cheap chips are used in cheap knock offs!) but the software has been hacked.
Offline cebbes30
« Reply #454 on: 18 February 2014, 21:48 »
Hello GolfMK7,
can you tell me if you have cruise control installed in your car without ACC.
Left button MFL CNL tekst?
Offline cebbes30
« Reply #455 on: 24 February 2014, 19:35 »
Hello,
I have get today a update to my car by the vw garage.
After update
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 L
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011227800350
   Coding: 00040846C24102FB0BA44080B11C07081000000000000000000000000000
   Shop #: WSC 13107 102 209715
   ASAM Dataset: EV_BCMCONTI 011001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 77FD0D57CE389FA6A59-8022
Before update
   Part No SW: 5Q0 937 084 L    HW: 5Q0 937 084 L
   Component: BCM MQBAB H   H14 0103
   Coding: 000C0846C24102FB0FA44080B11C07080000000000000000000000000000
   Shop #: WSC 00028 028 00001
   ASAM Dataset: EV_BCMCONTI 010001
   VCID: 4189A38FD07C1116DBD-8014
The problem wit the update is that all personel adjusment are gone.
So i have manage that back to befor update, only one thing i cant get work.
The static cornering lights!!!
Left Fog:
(1)-Leuchte12NL LB45-Lasttyp 12                                              10 - Normal schienwerfer
(2)-Leuchte12NL LB45-Lampendefektbitposition 12                           00
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12            00
(4)-Leuchte12NL LB45-Lichtfunktion A 12                                      Nebellicht links
(5)-Leuchte12NL LB45-Lichtfunktion B 12                                      not active ??????
(6)-Leuchte12NL LB45-Dimmwert AB 12                                      100
(7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12                      Always
Right Fog:
(1)-Leuchte13NL RB5-Lasttyp 13                                             10 - Normal scheinwerfer
(2)-Leuchte13NL RB5-Lampendefektbitposition 13                      00 Cant cjange this
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13      00 Cant change this
(4)-Leuchte13NL RB5-Lichtfunktion A 13                                      Nebellicht rechts
(5)-Leuchte13NL RB5-Lichtfunktion B 13                                      not active ????
(6)-Leuchte13NL RB5-Dimmwert AB 13                                      100
(7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13                      Always
Can anyone tell me what i need to change, static cornering is a nice futere and want this back..
I dont now anymore what i have done!
Offline cebbes30
« Reply #456 on: 24 February 2014, 21:18 »
Hello
I have resolve it, the problem was the car mus not be running! when you want to recode this.
after turning the ignition to ON i have enable this!
5.Kanal (5) Leuchte12NL LB45-Lichtfunktion B12 auswählen
6.Wert auf Abbiegelicht links anpassen
7.Kanal (5) Leuchte13NL RB5-Lichtfunktion B13 auswählen
8.Wert auf Abbiegelicht rechts anpassen
Offline mcmaddy
« Reply #457 on: 25 February 2014, 06:46 »
If your using vcds then the ignition always needs to be on for coding changes.
Offline GrahamFR
« Reply #458 on: 02 March 2014, 17:19 »
I had to reboot after a while but I still got the error message on drl brightness which is annoying as that's the one I really want!
Ok im an idiot, had another go today at the drl turns out what I thought was the right channel wasn't. I was looking under light function dimwert cd, instead I should have kept scrolling near the bottom to find leutche or what ever it is, mission accomplished finally!
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline TheCarMadDad
« Reply #459 on: 04 March 2014, 04:32 »
My friend has a Genuine VCDS cable for his mk4 Golf, would this fit my mk7 (when I finally get it) so I can work some magic?
2014 Mk7 Golf GTD 5dr | Tornado Red | Keyless Entry | Climate Comfort Screen > Which means I also have the ATP. Also fitted with DTUK Stage 2 box ...Loving every second behind the wheel!
Previous...
2008 Toyota Prius T Spirit (fastest 0-15mph car I have ever owned :p )
2005 Subaru Legacy 2.5 SW
2003 Lexus IS300
2002 Seat Leon Cupra R
