Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1121037 times)
Offline mcmaddy
Re: MK7 and VCDS (VAG-COM) thread
« Reply #460 on: 04 March 2014, 07:27 »
Unless it's one of the newer cables which is backwards compatible then unfortunately it won't work.
Offline TheCarMadDad
« Reply #461 on: 04 March 2014, 16:09 »
Hmmm, how can i tell whether it is one of the newer cables???
2014 Mk7 Golf GTD 5dr | Tornado Red | Keyless Entry | Climate Comfort Screen > Which means I also have the ATP. Also fitted with DTUK Stage 2 box ...Loving every second behind the wheel!
Previous...
2008 Toyota Prius T Spirit (fastest 0-15mph car I have ever owned :p )
2005 Subaru Legacy 2.5 SW
2003 Lexus IS300
2002 Seat Leon Cupra R
Offline GrahamFR
« Reply #462 on: 04 March 2014, 19:43 »
If it fits would be my best guess...
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline rocknob
« Reply #463 on: 04 March 2014, 19:51 »
It depends in the type of cable. Ross-Tech make a variety of cables and they have a pretty good application list here http://www.ross-tech.com/vag-com/cars/applications/golfjetta.html
The plug is the same for all cars since the 90's
Current Car :  Tornado Red VW Golf GTI DSG DCC ParkAssist Xenons
Offline C2K
  • Northern Monkey
« Reply #464 on: 04 March 2014, 21:40 »
My friend has a canbus genuine ross tech lead but the battery charge function isn't even there on my bw51 as per guide. Activated the setting for rear lights on with drl but nothing happened. Really want that change too. :(
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
Offline itavaltalainen
« Reply #465 on: 04 March 2014, 22:17 »
try channel "No-Voltage display" and change to display.... battery state label does also not exist on mine but no voltage display works :)
« Reply #466 on: 04 March 2014, 23:48 »
Ha, I'm working in Burton right now in the brewery...
Previous...
2003 Lexus IS300
« Reply #467 on: 04 March 2014, 23:51 »
Would you guys be able to tell if I posted a pic of the cable?
Previous...
2003 Lexus IS300
Offline mcmaddy
« Reply #468 on: 05 March 2014, 06:25 »
The older cable won't work with newer cars but post a pic anyway.
Offline C2K
  • Northern Monkey
« Reply #469 on: 05 March 2014, 22:00 »
Cool thanks, will try that.  :smiley:
